wich is the best head for a B20..
Old Jun 5, 2003 | 12:12 PM
ppjanson13's Avatar
Default wich is the best head for a B20..
I have a 98 CRV...im looking to upgrade the head, and i still dont know if its best to go to vtec or just nonvtec./..
I;'ll apreciate all your comments cause right know i dont know....also i have a supercharge and plan intall it with the new head, i know thants important too...
Thanks.
Old Jun 5, 2003 | 01:11 PM
crxchris's Avatar
i would get the b16a head if possible do a port and polish and its the same as the type r head
Old Jun 5, 2003 | 03:12 PM
AfroThunderEF9's Avatar
Default Re: (crxchris)
^---im wit him b16a head
Old Jun 5, 2003 | 06:33 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxchris &raquo;</TD></TR><TR><TD CLASS="quote">i would get the b16a head if possible do a port and polish and its the same as the type r head</TD></TR></TABLE>
type r head, has a slight port job. i would call it a clean up job, rather than a port job! you can get a b16 head, and sendt it to get a fuul port job and valve angle job
Old Jun 8, 2003 | 03:27 PM
sparq's Avatar
B16 head has 5% better flow over the B18c
Old Jun 8, 2003 | 05:45 PM
91hatchcivic's Avatar
Default Re: (sparq)
how much does the p&p and angle valve job usually cost?
Old Jun 8, 2003 | 09:24 PM
Ef Whore's Avatar
Default Re: (91hatchcivic)
1st gen. b16 head....clean it up though(drop a little dough into it )
Old Jun 8, 2003 | 09:28 PM
carrcarr's Avatar
Default Re: (Ef *****)
B16 head is the best flowing honda head
Old Jun 8, 2003 | 09:44 PM
SimbaDogg's Avatar
Default Re: (carrcarr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carrcarr &raquo;</TD></TR><TR><TD CLASS="quote">B16 head is the best flowing honda head</TD></TR></TABLE>
....ok, now who told you this?
Old Jun 9, 2003 | 03:20 AM
ThatRicerDaniel's Avatar
Default Re: wich is the best head for a B20.. (ppjanson13)
sorry im confused .. you have a 98crv motor or a 98crv? if so have you seen that Mugen Crv. that **** is bad ***...
Old Jun 21, 2003 | 04:32 PM
.jacob's Avatar
Default Re: wich is the best head for a B20.. (NitrousDreamz)
If I get a B18C head with a nice Port Flow p&p job wouldn't it be a better head to use on a B20 block?
-Jake
Old Jun 21, 2003 | 05:54 PM
714phil's Avatar
Default Re: wich is the best head for a B20.. (Ninety2SiR)
just a side note- if you use the stock b20 bottom end with a vtec head, cut the valve reliefs on the pistons.
Old Jun 21, 2003 | 06:00 PM
smokey2.0's Avatar
Default Re: wich is the best head for a B20.. (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">just a side note- if you use the stock b20 bottom end with a vtec head, cut the valve reliefs on the pistons. </TD></TR></TABLE>
you'll only need to do this if you're using a b20z(stock bottom end) with a b16 head with ctr cams(you can use itr cams, gsr, or b16 cams without cutting the valve reliefs)! if you're using a gsr head on a b20z block, you'll be needing to open the valve reliefs in order to use any cams other than first gen b16 cams! i speak fom my own experince on my b20z bottom end!
philosofy1
Oct 3, 2007 12:54 PM
cacahead1
Jun 11, 2005 07:29 AM
Home Skillet
Dec 6, 2003 09:43 AM
SuPeR_MaN
12
Sep 14, 2002 06:19 PM
No-Gi
Jun 9, 2002 01:06 PM
