What is the piston to wall clearance that you fully built turbo guys are using?
75.5mm bore, Endyn/Wiseco pistons. I used .0029". I also used .012" on the upper ring gap and .012" on the lower. 500 miles on the engine so far and it's running good.
The pistons don't slap nearly as much as I was expecting.
Sonny
it depends on your pistons set, some have more or less silicone in it, therefore, more or less clearance needed for expansion. Stock run .001 due to high silicone, most aftermarket runs anywhere from .020 to .035.
stan
stan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote"> most aftermarket runs anywhere from .020 to .035.
stan</TD></TR></TABLE>
or bigger...
or bigger...
That will depend on what piston manufactor you use. Endyn calls for very close clearances, .0028-.0029". Very tight!
art
art
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
or bigger...</TD></TR></TABLE>
especially on 700 HP street car
my arias are set at .035. they recommended me the clearance at .030 to .040, i chose a nice medium. well, actually i talked to the guy who machine my block, he said it was closer to .0345 but whatever.
AaronJ
May 1, 2008 05:42 PM
.adam.
Nov 21, 2007 02:39 PM
