**What are good cams that go with a supercharger!?**
Old Jun 4, 2003 | 01:30 PM
russian_racer's Avatar
Default **What are good cams that go with a supercharger!?**
I know there are turbo cams out there but are there any cams out for a supercharger...or...will a stage 2 or 3 yeild good power increase?
(cams for supercharged LS and B16a--for a daily driver!!) Thanx!
Old Jun 4, 2003 | 03:43 PM
turbolshatch's Avatar
Default Re: **What are good cams that go with a supercharger!?** (russian_racer)
id say stay stock you wont get that much power for the money
Old Jun 5, 2003 | 06:27 PM
Default Re: **What are good cams that go with a supercharger!?** (turbolshatch)
anyone else!?
Old Jun 5, 2003 | 08:04 PM
fxrob's Avatar
You definately don't want to run a stage 2 or even a stage 1 cam. If you don't have any way to dyno tune, then stick with your stock cam. You want to use a turbo cam that has high lift, short duration. If there is too much overlap, like cams designed for NA motors, then your boost will go right out the exhaust and you will loose power.
Old Jun 5, 2003 | 08:10 PM
Blaze45's Avatar
Brrraaaap!
Default Re: **What are good cams that go with a supercharger!?** (fxrob)
http://www.ef-1.com the L21 cams are great if your non VETC
Blaze
Old Jun 5, 2003 | 09:18 PM
vactor's Avatar
find something with a good lobe separation angle (less overlap) and long duration. not sure there is anything available for vtec motors for this ... i would say stick with stock and some adjustable cam gears and wait and see if anyone makes a se tof blower cams for the B series vtec motors.
Old Jun 6, 2003 | 01:26 AM
pissedoffsol's Avatar
25 Year Member
buy these from darcy--
https://honda-tech.com/zerothread?id=497774
TravisBiggie
Jan 26, 2016 11:01 AM
Pr0j3ctxH@tchx90
Apr 20, 2007 03:38 AM
djay86
Jan 9, 2004 02:14 PM
White S2k
Dec 1, 2002 06:35 AM
The Punisher
Dec 19, 2001 06:47 PM
