dsm 450's + fpr (not rising rate) = better injector response?
with all the issues people are having with the 450's i wonder if an fpr would help startup/idle/part throttle? perhaps bumping it up to around 42psi or so would allow shorter pulses?
Well on a cold start-up that wouldn't help because your ecu is runing under pre-programed settings until it's warmed up. As far as part throttle that would indicate that it needs to be tuned better on a dyno, and idle, would also be v-afc setting that would effect that. Otherwise you would have to run extreemly low fuel pressure to adversly effect the amount of fuel entering the engine during idle.
BorderM3
Dec 8, 2002 08:03 PM
