safc installed not tuned now throwing codes,help pls
its throwing absolute manafold pressure which is 3 and o2 check which is 1 both have come on this morning on way to work installed the afc on saturday,anyone ever installed and not tuned pls help.
not sure about the o2 code, but for the MAP sensor code--CEL 3--either the sensor is broken or there's a loose wire somewhere. so as suggested already, check the wiring. the ECU is very picky about it because the "engine side" of the map sensor wires goes to one AFC wire and the "ecu side" goes to another, so if there's any kind of break in the connection, it'll throw a code.
nicko360
Aug 18, 2007 10:15 PM
jus_spooln_wicha
Jun 13, 2007 12:04 PM
