Which Sways will fit?
Yes, the front and rears bolt up. You will need gsr or itr rear lca's to bolt up the endlink. And if you get itr lca's you will need the itr shocks or some other shock meant for an itr. You will also want some kind of reinforcement for your subframe. You can either make your own with washers and plates or get a beaks kit a http://www.beaksproducts.com.
13mm and 14mm swaybars work fine with a lower tie.
You will run into problems with an ITR bar and SRK's because of the reinforcement plate.
I believe the solution is longer bolts for the LCA. He sells 'em for 10 dollars.
comptechgsr
Sep 15, 2002 12:00 AM
