ITR Suspension
ITR Suspension
hi everyone i have a 92 eg hb. i was just wondering if the ITR front sway bar fit for my car? I know the Integra GSR fits. please help thanks
Re: ITR Suspension (abolish415)
well im gunna step out on a lim here and say yes........itr bars fit any honda---i usally dont say this but....damn use the search or just common sense
The ITR bar fits, but I believe you need the LCAs in order for it to work.
The ITR bar won't fit on an EK, so it doesn't work with any Honda.
Re: ITR Suspension (notatuma)
gsr and itr front sway bars = same. they are both 24mm
gsr rear sway bar = 14 mm
itr rear sway bar = 22 mm
you can use the itr rear sway bar on your eg hatch, by using integra rear lca's, or the itr rear lca's, but using itr rear lca's will require you to run itr shocks.
and to use the rear sway bar, a mounting kit is reqquired
http://www.beaksproducts.com they sell a mounting kit to use the itr rear sway bar on an eg.
i bought the front stablizer wit the front sway. will that fit also? wat do you mean changing the lca? i thought you only have to change the lca if your installing the rear sway. if i have the front i have to change the front lca?
Modified by abolish415 at 5:00 AM 10/3/2003
Re: ITR Suspension (Fowler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fowler »</TD></TR><TR><TD CLASS="quote">The ITR bar fits, but I believe you need the LCAs in order for it to work.
The ITR bar won't fit on an EK, so it doesn't work with any Honda.</TD></TR></TABLE>
well i dont own a ek....i have a ej6 and my itr bar fit on mine pretty well
Re: ITR Suspension (99EKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99EKhatch »</TD></TR><TR><TD CLASS="quote">
well i dont own a ek....i have a ej6 and my itr bar fit on mine pretty well</TD></TR></TABLE>
Stop nitpicking, it's stupid. I would love to see how you got an ITR front sway bar on your Ek or EJ6 or 96-00 civic.. or whatever you want to call it.
It's also ironic that you own an EJ6 when your name says otherwise.
