alternative to itr lca's/rearsway?
is there any alternative to getting the itr rear sway 22/23mm w/ the itr lca's...
different sway bars that mount up to the stock lca's?
Re: alternative to itr lca's/rearsway? (Boost Pressure)
you don't need to use itr lca's. You can use gsr ones. Then use a itr 22mm swaybar. go to http://www.hybridautomotive.com for the gsr rear lca package and swaybar. it's the cheapest way to go in my opinion.
s
s
Guest
Posts: n/a
Re: alternative to itr lca's/rearsway? (comptechgsr)
Go GSR.
The ITR bar is like $60 from the dealer
Re: alternative to itr lca's/rearsway? (B18C-EJ1)
isn't it just easier to use the ITR LCA's?
i mean, i installed the itr bar with bsq's kit on my gsr, but wouldnt the itr lca's be direct bolt in...
also,
what are the going rates on both,
itr and gsr lca's?
also,
itr and gsr lca's?
Re: alternative to itr lca's/rearsway? (E Prepared)
the bar is pretty much a direct bolt in. With the ITR lca's you're still gonna need BSQ's kit because the subframes are different on the GSR's and the ITR's. The ITR's have a beefier subframe because of the larger rear bar. Nothing you can do about the subframe. The swaybar attaches the same no matter if it's the ITR lca or the GSR lca. I think you've got something mixed up or confused. Yes, the LCA's will include bushings but they're going to be REALLY expensive from the dealer. Better off getting them used from http://www.hybridautomotive.com. Jeff is on this board and is a really good guy to deal with. Check out his website.
s
[Modified by stevel, 4:48 PM 9/14/2002]
s
Re: alternative to itr lca's/rearsway? (stevel)
s
s
mister2racer
08-04-2003 12:28 AM
