CX and EX wire harness
Old Jun 1, 2003 | 09:29 PM
LDxShyGuy's Avatar
Default CX and EX wire harness
hey guys, i have a 92 cx wire harness and im wondering if its the same as the ex one, since the 92 canidian made cx is already prewired for vtec...should it be the same?
(its probly a noob question but i need to know)
Old Jun 1, 2003 | 09:37 PM
SpoonFedHatch's Avatar
hmmm....in america, the EX has the VTEC plug, and the CX does not.....canadian trims must differ.....sorry i cant help much
Old Jun 1, 2003 | 09:39 PM
Touch's Avatar
Default Re: (SpoonFedHatch)
mine was made in canada too. and the answer is nope. they are wired for vtec from the shock tower to the ecu, but the engine harness is non vtec.
If you're doing a vtec swap, an 92-95 ex/si harness will bolt right up. good luck
Old Jun 1, 2003 | 11:07 PM
elwood's Avatar
Default Re: (Touch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch &raquo;</TD></TR><TR><TD CLASS="quote">mine was made in Canada too. and the answer is nope. they are wired for vtec from the shock tower to the ecu, but the engine harness is non vtec.
If you're doing a vtec swap, an 92-95 ex/si harness will bolt right up. good luck</TD></TR></TABLE>
In America so would the vx harness.
It was made in Canada but it's not a Canadian trim model. If yours was wired for vtec then
they should be the same, unless the ex/si had the abs sensors on it, witch I don't think that
the cx harness would.
bigboi408
18
Nov 1, 2020 11:42 AM
91bluehatch
16
Apr 1, 2009 10:04 AM
2DoorBandit
Mar 27, 2006 05:36 AM
Doeboy
Nov 18, 2004 09:31 PM
itr0032
Nov 20, 2001 04:31 PM
