Brake Tech: Steps to replace warped Rotors.
Old Jun 1, 2003 | 04:58 PM
Remy E. LeBeau's Avatar
Default Brake Tech: Steps to replace warped Rotors.
I need to replace my front rotors on my 98 Civic HB and would like some tech info if possible. From what I understand the swap should be simple. let me know if im missing a step.
1. remove wheels, jack the car up of course
2. Loosen the two bolts on caliper and remove.
3. Slide off rotor.
4. Clean backing plate and place new rotors on
5. Replace caliper and re tighten bolts.
Is their anything I am missing? Does anyone have a link to a more technical site with pics? Thanks a lot.
Loc
Old Jun 1, 2003 | 05:42 PM
s o h c's Avatar
Default Re: Brake Tech: Steps to replace warped Rotors. (Loc)
sounds right but there are 2 screws in each rotor that hold it to the hub, and they are a bitch to get loose. most people end up just drilling them out, this is probably the most annoying part of the install but all in all it should take about 10-15 min for each corner
Old Jun 1, 2003 | 05:48 PM
The Destroyer's Avatar
Default Re: Brake Tech: Steps to replace warped Rotors. (g unit)
If your rotors are warped, u can actually just bring them to a car place (forget wich) and they will cut each rotor for a cheap price. did it on the minivan a few weeks back.
Old Jun 1, 2003 | 06:25 PM
s o h c's Avatar
Default Re: Brake Tech: Steps to replace warped Rotors. (MagillaGorilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagillaGorilla &raquo;</TD></TR><TR><TD CLASS="quote">If your rotors are warped, u can actually just bring them to a car place (forget wich) and they will cut each rotor for a cheap price. did it on the minivan a few weeks back.</TD></TR></TABLE>
depends on how warped the rotor is though, some cant be saved
Old Jun 1, 2003 | 06:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g unit &raquo;</TD></TR><TR><TD CLASS="quote">
depends on how warped the rotor is though, some cant be saved</TD></TR></TABLE>
Yea but if it wasnt that bad and he was on a budget this oculd save him some $$
Old Jun 1, 2003 | 06:31 PM
gamby's Avatar
2 screws and a cotter pin?! I had no idea it was that easy!!!
Here's my n00b question--can I change brake pads without bleeding the system???
I should address this before I do 2 auto-x's and an HPDE in a 3 week period!!!
Old Jun 1, 2003 | 08:12 PM
SpoonEK2's Avatar
Default Re: Brake Tech: Steps to replace warped Rotors. (gamby)
There is no cotter pin...just the 2 screws. Use an impact driver to remove them.
You don't need to bleed the brakes after a pad change, but since you will be tracking it, it's a good idea.
Old Jun 1, 2003 | 08:58 PM
gamby's Avatar
Default Re: Brake Tech: Steps to replace warped Rotors. (SpoonEK2)
Old Jun 1, 2003 | 09:19 PM
ill phil's Avatar
It's not necessary, but its a real good idea to pick up new pads when you replace rotors. Rotors wear to pad, pads wear to rotors, etc. You get the idea, it would add some life to your rotors.
Old Jun 1, 2003 | 10:01 PM
rhettster's Avatar
Pep Boys does it for $8 per rotor.
Make sure you clean the hubs really well before you mount the rotors. Don't want any rust in there to make the rotors untrue.
eastbayrep
15
Oct 14, 2006 03:26 PM
99simoder
10
Nov 28, 2005 10:14 PM
Jaydeep
34
Oct 18, 2004 05:28 AM
Flux
Apr 13, 2003 11:05 AM
deviant1
Dec 21, 2002 04:21 AM
