ITR pistons in GSR?
Old Jun 1, 2003 | 03:57 PM
I wanna be Steve!'s Avatar
Default ITR pistons in GSR?
Like the title says, just curious if ITR pistons/rods would fit into a B18C1. I assume it would, but just want to make sure before I dish out the $$. Thanks in advance.
Old Jun 1, 2003 | 04:05 PM
function83's Avatar
Default Re: ITR pistons in GSR? (I wanna be Steve!)
yes they do.
Old Jun 1, 2003 | 04:09 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: ITR pistons in GSR? (djhatch)
HAHA, what is that Tom Green pic from?
Edit- I heard using B16 pistons will yield a littler higher CR
Old Jun 1, 2003 | 04:12 PM
Default Re: ITR pistons in GSR? (Emerika)
Pic is from the movie, "Stealing Harvard"...in the movie Tom Green says, "I wanna be Steve!"...just thought it went together, and walah!
Thanks for the info on the B16 pistons, what did you mean by CR though??
Old Jun 1, 2003 | 04:26 PM
function83's Avatar
compression ratio
use this site to figure what compression you get with certain pistons.
http://www.c-speedracing.com/h...c.php
usdm itr pistons: 10.8 to 1 cr
usdm b16 pistons: 11.3 to 1 cr
Old Jun 1, 2003 | 04:36 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">HAHA, what is that Tom Green pic from?
Edit- I heard using B16 pistons will yield a littler higher CR </TD></TR></TABLE>
any b16 pistons? really? how so. can you explain that? thanks.
Old Jun 1, 2003 | 04:52 PM
function83's Avatar
Default Re: ITR pistons in GSR? (Soup ****)
yes any b16 pistons.......will yield a higher compression becuz they are
more domed than itr pistons. if you use p30 b16 pistons you will get even
more compression.
Old Jun 1, 2003 | 04:53 PM
navin's Avatar
PR3 pistons yield the same compression as JDM ITR Pistons if I recall...
PM Trey about this, he has had both of the piston setups...
o0o_tylor_o0o
Feb 27, 2009 08:40 PM
stonet149
12
Nov 2, 2008 09:29 PM
crxowner
Jul 26, 2005 05:57 PM
boobz
Jul 25, 2004 08:48 PM
palmeref9
Jan 28, 2004 08:25 PM
