hesitiation like a sob backfire misfire blah blah
Old Jun 1, 2003 | 02:10 PM
Urban Business
Guest
Posts: n/a
Default hesitiation like a sob backfire misfire blah blah
got home last monday washed the ka. start it up it would hesitate once in 3rd gear around 3k. the engine bay did *not* get wet. since ive destroyed 4921 dizzy's im asuming its dizzy related so i get a new one. new dizzy coil cap rotor blah blah. plugs are 2 weeks old etc etc. no go.
now its getting worse. i start the car it backfires, i try to drive it @ any rpm low or high throttle it hesitates like a sob.
its throwing no codes either
things that are new:
o2 sensor
dizzy
cap
rotor
retimed everything
advanced the timing and retarded the timing
plugs
grounds are fine
swaped ecus
ive searched a lot on this issue. everything points to ignition but mines dead new. could this be an injector thats taking a ****?
stumped
Old Jun 1, 2003 | 05:31 PM
Urban Business
Guest
Posts: n/a
Default Re: hesitiation like a sob backfire misfire blah blah (limoZeen)
Old Jun 2, 2003 | 12:29 AM
Urban Business
Guest
Posts: n/a
spark is definitely arcing over but some where inside the dizzy. both the old one and new one are doing this, cap and rotor are new. they fuct up?
Old Jun 2, 2003 | 06:25 AM
ThatRicerDaniel's Avatar
have you ever ran nitrous?
Old Jun 2, 2003 | 07:19 AM
matt j's Avatar
Default Re: hesitiation like a sob backfire misfire blah blah (NitrousDreamz)
did you have a mpfi swap? i cant remember if you did or not, check the cylinder positioning sensor wires.
Old Jun 2, 2003 | 08:04 AM
slowpokesi's Avatar
Default Re: hesitiation like a sob backfire misfire blah blah (mattED6)
you have your plugs in the right order? try swapping them around, maybe you interpreted the picture in the manual wrong.
Old Jun 2, 2003 | 01:19 PM
Urban Business
Guest
Posts: n/a
Default Re: hesitiation like a sob backfire misfire blah blah (slowpokesi)
yeah its an mpfi swap. plug wires are in the proper order,
timing was off fixed that, it backfires a <FONT SIZE="8">TON</FONT> when its under load. you can hear spark arcing all over the place inside the dizzy, so i yet again replaced the cap and rotor. didnt help anything. throwing no codes
im stumped
Old Jun 2, 2003 | 01:32 PM
are you grounding out a wire inside the dizzy maybe?
Old Jun 2, 2003 | 01:50 PM
Urban Business
Guest
Posts: n/a
idk its brand new. i briefly looked at it and didnt see any exposed wires etc. i really dont know. seem the more i try to do to solve the problem the worse it gets.
Old Jun 3, 2003 | 09:21 AM
Urban Business
Guest
Posts: n/a
fixed. had a broken plug wire
Old Jun 3, 2003 | 09:59 AM
slowpokesi's Avatar
hahahaha i knew it had something to do with the wires !!!
Old Jun 3, 2003 | 10:00 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limoZeen &raquo;</TD></TR><TR><TD CLASS="quote">fixed. had a broken plug wire </TD></TR></TABLE>
You see Limozeen, it's usually the stupidest, easiest thing that goes wrong!!!
Old Jun 3, 2003 | 05:02 PM
Urban Business
Guest
Posts: n/a
Default Re: hesitiation like a sob backfire misfire blah blah (Mr. S)
however, low rpms WOT and high rpms WOT it still hesitates
Old Jun 3, 2003 | 05:11 PM
7PSI CRX's Avatar
Redo the ignition timing, and check the spark plug from the cylinder that had the bad wire.
You changed ALL the spark plug wires, or just the one?
If 1 was bad, the others can't be far behind.
Old Jun 4, 2003 | 11:56 AM
Urban Business
Guest
Posts: n/a
Default Re: hesitiation like a sob backfire misfire blah blah (7PSI CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">Redo the ignition timing, and check the spark plug from the cylinder that had the bad wire.
If 1 was bad, the others can't be far behind.</TD></TR></TABLE>
timing was redone, cap, rotor, plugs and all wires are brand new. its like fuel kill (sillilar to when a crank angle sensor takes a **** cept higher up in the rpm band). it also hesitates once out of 1st at really low rpms. think it could be a bad injector? if it was id assume it would ride like *** in general.
Zachary Lentz
Jun 9, 2016 08:02 PM
mss8rc
13
Jan 19, 2010 10:17 AM
Coltmorris
11
Sep 22, 2009 12:29 PM
91' LS-VTEC
Apr 5, 2006 12:06 PM
ApolloSpeed
May 2, 2005 12:47 PM
