ek drop question.
From: I have crack runin through my veins, seriously, United States
im looking to drop my 00 ek soon....probably 1.7 front and rear. should i get a camber kit...or will i be alright without one. sorry for not searching first guys...
it won't be absolutely necessary but it wouldn't hurt, either. When you get an alignment after dropping the car, they'll usually give you camber specs. You can decide from that if you need/want a camber kit or not. I'm dropped 2.5"/2.25" front and rear and don't use one. I should ... but i don't.
I'll probably get one soon, though.
You dont need a camber kit, it will just save the life of your tires. I roughly have a 2 inch drop on my ek and i go through tires sort of quick because i am not using a camber kit.
i'm 1.75 front adn 1.5 rear, i did the rear washer mod for the back camber (cost $2 and now its at factory specs) and the front is at -1.5º of camber. i got a good alignmetn ($60) and my tire wear is perfect.
whoever says that their camber messes up their tires are wrong, its all about the toe in/out being fixed by getting an alignment.
Matthew Dorey
23
Mar 4, 2016 04:14 PM
LSI_EK
Apr 15, 2008 08:36 PM
LSI_EK
Apr 9, 2008 01:54 PM
