Thinking about turbo......help me out guys
Ok, Ill list my setup in the following post. But right now I want to go turbo. And was wondering what my options were. Now what I was wondering is if I sell some of the parts I am running currently I could buy a turbo kit. I guess what Im asking is what could I sell off my current setup that I don't need for a turbo kit or wouldn't be able to use with turbo. Also, throw me a ballpark figure on what I am going to spend on the turbo kit. I don't want to lose too much reliability in the car so I will not be running that high of a psi.....thanks guys.
here's my setup.
95' GSR w/ 56,000 miles.
AEM ITR CAI
AEM Ported GSR T-body
Skunk 2 ITR Intake Manifold
DPR Stage 6 Headwork-- stainless steel, oversized, ceramic coated valves, titanium VTEC X-over pins, titanium retainers, ITR valvesprings, milling, clover-leaf welded combustion chambers. Flow-benched to match cams, Mugen Headgasket, 11.8 compression
Toda Racing Header
Carsound Cat
Kakimoto R ITR stainless steel 70mm catback
Apex-i VAFC
No P/S, A/C, Cruise Control
Energy Suspension Engine Mounts
Autometer oil pressure, oil temp, water temp and A/F gauges
Transmission:
Kaaz 1.5 Way LSD
JDM 4.785 FD
Type R Tranny (Brand New)
Fidanza 7lb. Aluminum Flywheel
Exedy Racing Street Clutch
Energy Suspension shifter busings
B&M Racing Short Shifter
Suspension:
Koni compression/rebound adjustable shocks
Neuspeed race Springs
Energy Suspension Hyperflex Bushing kit
Neuspeed front and rear upper strut tower bars
Comptech 22mm rear lower sway bar
Eibach Camber correction kit
AEM ITR CAI
Toda Racing Header
Carsound Cat
Apex-i VAFC
Transmission:
Kaaz 1.5 Way LSD
JDM 4.785 FD
Suspension:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps »</TD></TR><TR><TD CLASS="quote">here's my setup.
AEM ITR CAI
Toda Racing Header
Carsound Cat
Apex-i VAFC
Transmission:
Kaaz 1.5 Way LSD
JDM 4.785 FD
Suspension:
Sell the following items:
your cai, and header.How much was milled off the head? put a stock head gasket back in, and sell your gauges, they won't help much, unless you want to keep tabs on the engine they won't hurt either.
A safe kit can be any kit if tuned properly. Expect to spend about $3,500 +/- a little for a comlete ready to run kit. drag, revhard, both make complete kits ready to bolt on, that will make decent power at a low boost setting.Another option for you would be to build your ow kit, since you already have the v-afc get some larger (450cc) injectors and a high flow fuel pump. That will take car of your fuel,
You could probably make your own kit for about $2k-$2,500...
AEM ITR CAI
Toda Racing Header
Carsound Cat
Apex-i VAFC
Transmission:
Kaaz 1.5 Way LSD
JDM 4.785 FD
Suspension:
Thanks man
......I've been hearing Revhard, Drag and Greddy.....I'd like to run anywhere around 250 whp. So, im not asking a crazy amount. I want a daily driver and reliable so I plan on the proper tuning and maintenance.
ok sell your cai, header, and forgot to read how big is that exhaust you may want to go with a 3 inch but dont have to. Also definetely lose the mugen headgasket. Skunk manifodl is good. I say you can sell your parts and get atleast $500 for them and then afterhourzracing.com sels revhard 2c for $2850 shipped, comes with everything you need to make 260 whp running around 7 psi. so looks like ull only spenmd about $2,00 or so and then may want to pick up soem greddy gauges boost/egt
I was runing short on time earlier so i didn't have a chance to post everything i wanted to.
Ayways if you go with a kit it's going to come with a fmu and inline pump that you'll probably sell to get some larger injectors. that way you can do the v-afc hack.
I would recomend doing your own kit because it may save you a little money.
Pick up a drag or custom manifold from sfp. $350
then find a good used intercooler or new custom one online for about $350
check cheapturbo.com for a nice t3t4 turbo $540 shipped. + tial 35mm wg $200.
then check jegs, or local muffler shop for some u-bend pipes (mandrel bent) for your downpipe and charge pipes $100
then either pick up a new bov or used from most anywhere. $100-$200
You have the v-afc, so pick up a high flow walbro 255lph fuel pump, and either a set of used rc 450cc injectors or used dsm injectors.
Then I recomend getting a msd btm to control your timing, that should be good for about 10psi and it will get you close to your 250whp.
Don't forget your plugs ngk bcpr7es-11's..
then you will have quality parts and save a little money
or go with a complete kit like the drag kit, sell the fmu and fuel pump to get a intank pump,btm, and injectors. and you won't have to mess with doing any custom work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
do you mean get the intank or the inline or both? I always get confused about this.
run an intank 255 hp walbro, but i dont see the point in larger injectors for low boost, i stay stay basic and KISS it. Currently im piecing together and its costing me about the same price as a complete kit, but i have some nice parts in KIT. I started out with a revhard kit, i think its a great beginners kit, which will net your goals with no problems. no need to make thigns difficult especially if this is your first turbo set-up
Right now I have a 70mm kakimoto Full exhaust. I should be able to keep this correct? And a carsound cat.
Thanks for the replies and help. This is all looking good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by disguy409 »</TD></TR><TR><TD CLASS="quote">
do you mean get the intank or the inline or both? I always get confused about this.</TD></TR></TABLE>
Get a intank, i'm not a fan of the inline and you definatly don't need both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikb20 »</TD></TR><TR><TD CLASS="quote">, but i dont see the point in larger injectors for low boost, i stay stay basic and KISS it. </TD></TR></TABLE>
Larger injectors + v-afc = more control over the tune of the engine. Since he already has the v-afc it's in his best intrest to go with larger injectors and use the afc to control them.
i'm also not a advocate of high fuel pressure, the lower your fuel pressure the better. (assuming your using a fmu set-up.)
i'm also not a advocate of high fuel pressure, the lower your fuel pressure the better. (assuming your using a fmu set-up.)</TD></TR></TABLE>
I agree. I have 440's w/ hondata and my fuel pressure doesn't go past 55 psi (if I remember correctly) under full boost (I know, I know, I'm a wuss for only boosting 6.5 psi
) . The fmu is sort of a bandaid if you ask me and it's not as precise as an a/f controller or standalone. I prefer standalone's, but like you said, he's already got the v-afc.
Email me about the toda header, I may be interested. jintexas18@yahoo.com
Thanks! Jason.
Thanks! Jason.
well what about selling vafc and picking up a hondata, RC 550cc and then tuning way better imo then getting a vafc and trying to tune your a/f with that using bigger than stock injectors.
Like i said KISS (keep is simple stupid)
Is the header still for sale? I got your IM yesterday but it would not let me reply, don't know what that was about. But anyways I'm still interested.
Thanks, Jason, jintexas18@yahoo.com
FBP#494
Oct 6, 2003 02:21 AM
