d16y8 in del sol...PLS HELP ASAP!!!
Old Jun 1, 2003 | 08:35 AM
TKL's Avatar
TKL
Default d16y8 in 94 del sol si..PLS HELP ASAP!!!
I need some seriously help...I ran into some problems last night doing the swap in my car...its a complete d16y8 swap (OBD II to OBD 1) and I had everything converted over but the rear mount..its seems to be short about 1 inch.I had to changed the driver side mount and left the other mounts the same. Pls help so i can complete this.any help is appreicated!!!
thanks
Modified by TKL at 9:50 AM 6/1/2003
Old Jun 1, 2003 | 09:02 AM
clm's Avatar
clm
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (TKL)
Is it an automatic to manual conversion? I think I recall reading soemthing about the transmission mount not being the same.
Old Jun 1, 2003 | 09:09 AM
TKL's Avatar
TKL
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (clm)
no its a 5 sp swap.
Old Jun 1, 2003 | 11:33 AM
vladd's Avatar
are you using the del sol mount or y8 mount for the back one? the stock one should work, or at least that's what i've heard.
Old Jun 1, 2003 | 11:41 AM
B.'s Avatar
B.
400 HP Club
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (civicdxtyper)
just wondering why you would go through all that to put a d16y8 back in?
Old Jun 2, 2003 | 03:00 PM
TKL's Avatar
TKL
Default Re: d16y8 in 94 del sol si..PLS HELP ASAP!!! (THE B)
the bottom end went out on the z6 so i decide to go with the newer motor. I changed the mount to the z6 rear mount and it worked.thanks everyone.
MichaeltsinEF
Nov 18, 2018 08:42 PM
sterlihs
Aug 12, 2013 07:13 PM
xmod
Apr 1, 2009 11:25 PM
H22AJSPEC
Feb 22, 2006 05:47 PM
BoostedEgHatchFl
May 21, 2005 03:44 PM
