2 to1 rod ratio?
Old May 31, 2003 | 08:00 PM
crooked muffler's Avatar
Default 2 to1 rod ratio?
possible to do this with a d15?
rod lengths deck height?
its obvious to have the longest rod possible... but i need more info
thnaks
Old May 31, 2003 | 10:29 PM
dfoxengr's Avatar
Default Re: 2 to1 rod ratio? (anti-ricecake)
none of your post makes any sense
Old May 31, 2003 | 10:48 PM
Suprdave's Avatar
Default Re: 2 to1 rod ratio? (hybridvteceg)
If I pull on a donkey will it make milk ona saturday before non with buttercup pillows?
Your post made about just as much sense as that sentence I wrote...
Suprdave
Old Jun 1, 2003 | 12:15 AM
AussieK24's Avatar
English Translation:
Is it possible to change components to obtain a 2 to 1 rod/stroke ratio in a d15 motor?
Do the rod lengths or the deck height cause a problem with this particular combination?
I believe that it's beneficial to have the rods as long as possible.
I need more information
thanks
PS: Dave, leave that poor donkey alone!!!
Old Jun 1, 2003 | 04:01 AM
J2turbo21's Avatar
Default Re: 2 to1 rod ratio? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">If I pull on a donkey will it make milk ona saturday before non with buttercup pillows?
Suprdave</TD></TR></TABLE>
Ohh i get it now
Old Jun 1, 2003 | 06:13 AM
dfoxengr's Avatar
Default Re: 2 to1 rod ratio? (J2turbo21)
a2:1 would be retarded.
Old Jun 1, 2003 | 07:35 AM
Suprdave's Avatar
I think Smokey Yunick was a big proponent of 2:1+ R\S Ratios....but you gotta remember this was on a Big Inch V8, so even if the 2:1 Ratio shifted your torque curve super-high, you would still have plenty of useable torque at low RPM.
Suprdave
Old Jun 1, 2003 | 07:38 AM
i've been reading Smokey Yunicks book
so it isnt possible to achieve a really high rod ratio in a honda engine
i know the CTR has a really high one
Old Jun 1, 2003 | 08:17 AM
TREVER's Avatar
It's possible with major destroking and/or deckplate.
Old Jun 1, 2003 | 02:44 PM
Bisimoto's Avatar
Default Re: 2 to1 rod ratio? (TREVER)
I was able to use a destroked D15b6 crank to the value of 80mm, and a 137mm LS rod to achieve a 1.7 rod ratio. Of course, the rod journals had to be enlarged to LS diameters, and the ls rods narrowed to a civic rod thickness.
By the way, the LS rods did not like high rpm and significant power, thus I had to upgrade in 2001.
Old Jun 1, 2003 | 03:00 PM
dfoxengr's Avatar
Default Re: 2 to1 rod ratio? (Bisimoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bisimoto &raquo;</TD></TR><TR><TD CLASS="quote">I was able to use a destroked D15b6 crank to the value of 80mm, and a 137mm LS rod to achieve a 1.7 rod ratio. Of course, the rod journals had to be enlarged to LS diameters, and the ls rods narrowed to a civic rod thickness.
By the way, the LS rods did not like high rpm and significant power, thus I had to upgrade in 2001.</TD></TR></TABLE>
that guys a genius. just saw your profile in the latest tuner or ss, whatever it was. always loved the single cam power youve made.
Drugs Are Bad
Sep 23, 2007 01:25 PM
boostedcivicsir
Welding / Fabrication
Jan 29, 2006 11:46 AM
MidShipCivic
11
Oct 17, 2004 05:36 PM
boosted3g
Jan 15, 2003 04:48 PM
sicivic
Oct 1, 2002 08:15 PM
