GSR gears in an ls case??
Can i put GSR gears in an ls case? Will they fit?? I have all the forks and everything else from a GSR tranny except the case, but i have an ls case.
Thanks
Thanks
Actually if you use the bearings for the gsr diff you should be fine. The case itself is the same on all B-series tranies, but for some reason Honda desided to use different bearings on the ls and si than the gsr and itr diff. The ring gear has to match the input shaft, sence they mesh together.
