GSR gears in an ls case??
Old May 31, 2003 | 04:32 PM
Burke's Avatar
Banned
Default GSR gears in an ls case??
Can i put GSR gears in an ls case? Will they fit?? I have all the forks and everything else from a GSR tranny except the case, but i have an ls case.
Thanks
Old May 31, 2003 | 04:51 PM
bretx0r's Avatar
Default Re: GSR gears in an ls case?? (Burke)
yes
Old May 31, 2003 | 06:21 PM
b18cTurbo's Avatar
Default Re: GSR gears in an ls case?? (bretx0r)
gsr, ls, itr, si ,gears are interchangeable exept differentiel for ls
Old Jun 1, 2003 | 04:58 AM
Burke's Avatar
Banned
Default Re: GSR gears in an ls case?? (sleeper007)
sweet!! i imagine i have to use the gsr forks though, right? also which diff should i use, the ls or the gsr
Thanks
Burke
Old Jun 2, 2003 | 05:33 AM
Burke's Avatar
Banned
bump> anyone know what diff to use???? THanks a lot!
Old Jun 2, 2003 | 06:26 AM
earl's Avatar
I believe you would have to use the ls diff and ls ring gear that matched
Old Jun 3, 2003 | 11:39 AM
Burke's Avatar
Banned
Default Re: GSR gears in an ls case?? (earl)
cool, i am putting hte case back on tonight
thanks for all the help
Old Jun 3, 2003 | 12:14 PM
Naterror's Avatar
Actually if you use the bearings for the gsr diff you should be fine. The case itself is the same on all B-series tranies, but for some reason Honda desided to use different bearings on the ls and si than the gsr and itr diff. The ring gear has to match the input shaft, sence they mesh together.
Old Jun 3, 2003 | 02:30 PM
earl's Avatar
Default Re: GSR gears in an ls case?? (Naterror)
The gsr ring gear bolt pattern is different than the ls/b16. Correct?
Old Jun 3, 2003 | 02:32 PM
Suprdave's Avatar
GSR\ITR Ring Gear = Same
LS\B16 Ring Gear = Same
You are correct.
Muuurph
May 7, 2009 02:01 PM
steveharrmr23
Transmission & Drivetrain
Oct 1, 2008 03:18 PM
HatchSpeeD
Jul 30, 2006 05:03 AM
1.8turbolsvtec
Jan 26, 2005 09:50 AM
Toda Party
Sep 18, 2003 02:59 PM
