JE 9:1 GSR pistons same CR in B16?
Old May 31, 2003 | 12:02 PM
blackANESE's Avatar
Default JE 9:1 GSR pistons same CR in B16?
I was just wondering if the compression ratio of some 9:1 GSR pistons would yield the same 9:1 in a B16?
Thanks guys.
Old May 31, 2003 | 12:26 PM
hybrid901's Avatar
Default Re: JE 9:1 GSR pistons same CR in B16? (blackANESE)
around 8:8:1
Old May 31, 2003 | 12:49 PM
Kataku2K3's Avatar
Default Re: JE 9:1 GSR pistons same CR in B16? (hybrid901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 &raquo;</TD></TR><TR><TD CLASS="quote">around 8:8:1</TD></TR></TABLE>
Less that that, the difference in the PR3 cylinder head volume (42.70cc) over the P72 (41.60cc) alone would drop you down to ~8.8:1... That is to say if you put a PR3 on a B18C block running JE slugs that yield a static compression ratio of 9.0:1 with an 87.2mm stoke, it's going to be less when you swap them into a B16A (77.4mm stroke, less volume at BDC)... In a B16A, 77.4mm x 81.0mm (std. bore) with a PR3 cylinder head you're looking at a static C/R of ~8.10:1... Hope this is understandable... Peace
Old May 31, 2003 | 01:46 PM
blackANESE's Avatar
Default Re: JE 9:1 GSR pistons same CR in B16? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">
Less that that, the difference in the PR3 cylinder head volume (42.70cc) over the P72 (41.60cc) alone would drop you down to ~8.8:1... That is to say if you put a PR3 on a B18C block running JE slugs that yield a static compression ratio of 9.0:1 with an 87.2mm stoke, it's going to be less when you swap them into a B16A (77.4mm stroke, less volume at BDC)... In a B16A, 77.4mm x 81.0mm (std. bore) with a PR3 cylinder head you're looking at a static C/R of ~8.10:1... Hope this is understandable... Peace</TD></TR></TABLE>
Gotcha
I thought it would lower it quite substantially but had wrong info. coming from all directions.
Thanks Kataku
jdm_vtec
Feb 28, 2007 09:43 AM
94sol
Nov 10, 2005 09:33 PM
careawholelot
Aug 29, 2005 07:42 AM
Boostage
Apr 24, 2005 11:31 AM
dEtSoOb
Mar 19, 2004 12:05 PM
