JE 9:1 GSR pistons same CR in B16?
Re: JE 9:1 GSR pistons same CR in B16? (hybrid901)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid901 »</TD></TR><TR><TD CLASS="quote">around 8:8:1</TD></TR></TABLE>
Less that that, the difference in the PR3 cylinder head volume (42.70cc) over the P72 (41.60cc) alone would drop you down to ~8.8:1... That is to say if you put a PR3 on a B18C block running JE slugs that yield a static compression ratio of 9.0:1 with an 87.2mm stoke, it's going to be less when you swap them into a B16A (77.4mm stroke, less volume at BDC)... In a B16A, 77.4mm x 81.0mm (std. bore) with a PR3 cylinder head you're looking at a static C/R of ~8.10:1... Hope this is understandable... Peace
Re: JE 9:1 GSR pistons same CR in B16? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 »</TD></TR><TR><TD CLASS="quote">
Less that that, the difference in the PR3 cylinder head volume (42.70cc) over the P72 (41.60cc) alone would drop you down to ~8.8:1... That is to say if you put a PR3 on a B18C block running JE slugs that yield a static compression ratio of 9.0:1 with an 87.2mm stoke, it's going to be less when you swap them into a B16A (77.4mm stroke, less volume at BDC)... In a B16A, 77.4mm x 81.0mm (std. bore) with a PR3 cylinder head you're looking at a static C/R of ~8.10:1... Hope this is understandable... Peace</TD></TR></TABLE>
Gotcha
I thought it would lower it quite substantially but had wrong info. coming from all directions.
Thanks Kataku
Gotcha
Thanks Kataku
jdm_vtec
02-28-2007 09:43 AM
