best b16a cams?
im thinking about getting some used type r cams, what gains should i expect from them and what other cams would you recomend, im never going turbo or going completely psycho with this motor. I just want a lil more pickup. Thanks
Type R cams are probably the best for what you want. If possible, use the CTR intake cam. Slightly better than ITR, but just slightly. Exhaust cam is the same.
JUN and Toda also make good cams that come in different stages if you want serious power.
I would say best bang for the buck would be the CTR intake cam and ITR exhaust cam. If you can afford a little more, go with some toda cams. You'll definitely want a valve train upgrade with the Toda's though.
Good luck,
James
Good luck,
James
what about type r cams, would i want to do the valves for the r cams? and wwhat should i expect to gain from all this ?.. thanks
As always take th time to dyno tune what you have done. As far as gains, I think the norm is about 10 WHP. More than likely you could get more if you have the means to tune them. Good luck
James
Hey B16CRX. Your in HB right? Which part, because i live there to. BTW your email address is almost the same as mine. Crazy ****. I'm a little younger however, but man that is wierd. Plus your first name might be the same as mine to.
Anyways, to answer the question ITR cams are the best bang for the buck. I made 201whp on my GSR motor a while back with those cams.
DOHCRX
Jan 30, 2003 12:05 AM
