Golden Eagle 90mm H22 Headgasket issue
Old May 30, 2003 | 11:56 AM
Robb's Avatar
Default Golden Eagle 90mm H22 Headgasket issue
Application - H22, Gloden Eagle sleeved, 90mm bore....I tried using a Cometic headgasket, and it worked for a while, I was wondering if anyone knows of an alternative. Can a stock be made to work?
Old May 30, 2003 | 12:36 PM
Finest's Avatar
Default Re: Golden Eagle 90mm H22 Headgasket issue (Robb)
I believe they *suggest* an OEM HG. Did you use any copper spray?
Also, is your block O-ringed or stepped? And how did the Cometic fail? (Properly torqued, I assume?)
Old May 30, 2003 | 12:39 PM
JG Luder's Avatar
You can speak with member GTR*lude here on H-T. I'm about 99% certain he had a 90mm h22a1. If he doesn't have an answer, let me know. There is a shop owner I'm friends with that has a 90mm h22, and I'd be glad to give you his name and number.
All of my head gaskets on my 89mm motor (and I rebuilt that often, so I've had A LOT) were stock gaskets that were bored out. They worked fine. I would double check that the 90mm is going to pan out for the stock one though. I know it's stupid thin in between the pistons... the sleeves are notched so they'll all fit in the block, and the walls are virtually touching eachother.
Old May 30, 2003 | 04:01 PM
Suprdave's Avatar
Default Re: Golden Eagle 90mm H22 Headgasket issue (Lone Luder)
I would imagine, that 90mm would be tough to seal...no matter what.
Make sure your not using the Cometic Fire Ring gasket with a stock deck.
Suprdave
Old May 30, 2003 | 07:12 PM
b19coupe's Avatar
Have Golden Eagle take an OEM gasket and bore it for you. Use Coppercoat by Permatex; I had sealing issues on my 84mm blocks, no matter what I tried, until I used the Coppercoat. Amazing stuff.
Old May 30, 2003 | 09:30 PM
JG Luder's Avatar
Default Re: Golden Eagle 90mm H22 Headgasket issue (b19coupe)
I used that copper coating stuff. My mechanic saw it and I got laughed at royally by half the shop.
Makes me wonder what they've seen that I haven't... you know?
Old Jun 1, 2003 | 02:16 PM
K20Ahondas's Avatar
We use the 90.5 mm head gasket from cometic no problems....
Old Jun 1, 2003 | 03:18 PM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lone Luder &raquo;</TD></TR><TR><TD CLASS="quote">I used that copper coating stuff. My mechanic saw it and I got laughed at royally by half the shop.
Makes me wonder what they've seen that I haven't... you know?</TD></TR></TABLE>
Old School thinking said that you only ran copper spray on Copper\Metal Headgaskets, but not OEM. If anything, your mechanic doesn't know all there is to know.
Old Jun 1, 2003 | 03:19 PM
Suprdave's Avatar
Default Re: Golden Eagle 90mm H22 Headgasket issue (1FSTCAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FSTCAR &raquo;</TD></TR><TR><TD CLASS="quote">We use the 90.5 mm head gasket from cometic no problems....</TD></TR></TABLE>
So you guys are running a 91mm Bore, eh? Big Powa...
Suprdave
Old Jun 2, 2003 | 11:58 AM
K20Ahondas's Avatar
Default Re: Golden Eagle 90mm H22 Headgasket issue (Suprdave)
actually just 90, but we like to run a bigger bore gasket.
Old Jun 2, 2003 | 12:50 PM
Finest's Avatar
MM or KMS?
Old Jun 2, 2003 | 01:38 PM
Robb's Avatar
Do you guys use any copper spray?
Old Jun 2, 2003 | 02:41 PM
K20Ahondas's Avatar
If i don't forget...
Old Jun 2, 2003 | 03:18 PM
Robb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FSTCAR &raquo;</TD></TR><TR><TD CLASS="quote">If i don't forget...</TD></TR></TABLE>
hehe...thanks for the help guys.
Old Jun 2, 2003 | 04:46 PM
Suprdave's Avatar
How often do you refresh the 90mm setup? You think a 89mm bore would have enough 'meat' for a streetish setup? I dont mean daily driver, but a street car.
To\From races.
Suprdave
Old Jun 2, 2003 | 05:14 PM
K20Ahondas's Avatar
sure 89mm can be street driven i use to drive one....
Old Jun 3, 2003 | 06:58 AM
Boostless97Lude
Guest
Posts: n/a
that reminds me, i need to buy some more copper spray b/c I ******* LEFT IT IN ATL WITH YOU!!!!!
sometimes i think i'd forget my ***** if it wasn't properly attached
Old Jun 3, 2003 | 06:59 AM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FSTCAR &raquo;</TD></TR><TR><TD CLASS="quote">sure 89mm can be street driven i use to drive one....</TD></TR></TABLE>
i am about to drive on an 89mm on my turbo Lude, just got the block back from the machine shop yesterday as a matter of fact
Old Jun 3, 2003 | 07:04 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Golden Eagle 90mm H22 Headgasket issue (Boosted97Lude)
oh, BTW, here are some pics gtr*lude's 90mm setup http://www.imagestation.com/album/?id=4292333025
Schister66
May 20, 2016 05:45 AM
darkstarsi
Nov 18, 2011 06:13 PM
turboD_EG
Nov 19, 2008 05:59 AM
h22dx
Apr 15, 2003 01:07 PM
ratherbewalking
Dec 16, 2002 12:29 PM
