Difference: RC440 and DSM450
Old May 29, 2003 | 04:24 PM
EggEX2000's Avatar
Default Difference: RC440 and DSM450
I am getting in an argument over injectors and that there is too big of a difference between with the DSM's and RC's....
Am I correct in my thinking that the DSM 450s will work with my car.
Background: I will be running the VAFC Hack on my car and everyone that I have talked to has reccomended the DSM's.
Thanks.
~Mike
Old May 29, 2003 | 04:27 PM
Hayasa15's Avatar
Default Re: Difference: RC440 and DSM450 (EggEX2000)
The DSM450 will work if you use the injector resistors. I dont see why they wouldnt work, it is just a cheaper alternative to the RC's
Old May 29, 2003 | 04:58 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Difference: RC440 and DSM450 (Hayasa15)
they flow 10cc more than RC's
Old May 29, 2003 | 05:07 PM
KOTSEMOTO's Avatar
The difference is about $250 retrail list price.
Old May 29, 2003 | 05:37 PM
Sonny's Avatar
I used them both on my car. JRSC @ 8 psi. I did not change the fuel maps at all when I went from RC440's to DSM450's.
Sonny
Old May 29, 2003 | 09:16 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: Difference: RC440 and DSM450 (Sonny)
RCs are saturated and the DSMs are peak and hold
Old May 29, 2003 | 09:24 PM
keebler65's Avatar
Default Re: Difference: RC440 and DSM450 (You_Get_Vapors)
i've been using DSM's and experience the all-too-common problems of part throttle jerking as well as very difficult starts when the motor is warm (not hot, not cold). if you have the choice, i would do it right and go with the RC's.
Old May 29, 2003 | 09:33 PM
Sonny's Avatar
Default Re: Difference: RC440 and DSM450 (keebler65)
The "warm start problem" is something I experienced with both types of injectors. I didn't experience any part-throttle problems with either set, but I understand that the part-throttle issues are a common symptom when using the VAFC hack.
Sonny
Old May 29, 2003 | 09:44 PM
@irborne's Avatar
you need this to run the DSM injectors
Honda Risistor Box / Resistor Pack
Old May 29, 2003 | 09:53 PM
civicqm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 &raquo;</TD></TR><TR><TD CLASS="quote">i've been using DSM's and experience the all-too-common problems of part throttle jerking as well as very difficult starts when the motor is warm (not hot, not cold). if you have the choice, i would do it right and go with the RC's.</TD></TR></TABLE>
Agreed, you should go with RC's, I think you will be a little happier in the long...Just my 2 cents.....
Old May 30, 2003 | 01:15 AM
Dee's Avatar
Dee
Default Re: Difference: RC440 and DSM450 (civicqm)
If you want ome saturated 550's I can get them from my RX-7 friends for $80~$125 for four injectors (price depends on the friend )
Old May 30, 2003 | 04:07 AM
MiraiZ's Avatar
I've been using DSMs for a while...never experienced such problems...you sure is not a tuning issue?
Old May 30, 2003 | 09:16 AM
Joseph Davis's Avatar
It's a AFC hack issue, not an injector issue. DSM 450cc work fine.
Old May 30, 2003 | 09:37 AM
EggEX2000's Avatar
Default Re: Difference: RC440 and DSM450 (J. Davis)
If the DSMs work fine, how did you get them to fit?
Old May 30, 2003 | 11:51 AM
MachAF's Avatar
Default Re: (GSRslowandswap)
I've heard people have issues with DSMs. Rough starts and throttle jerking issues.
Old May 30, 2003 | 01:58 PM
shermanyang's Avatar
Default Re: (MachAF)
I have the blue top DSM injectors and I haven't had a problem with them yet. well, on cold starts my RPM fluctuates until my motor warms up but i can live with that since i drive it right away. my car hasn't died on me yet and and i love my dsm injectors. hopefully after i get it dynotuned this tuesday i'll be running alot better as well. props to cheap parts!!
Old May 30, 2003 | 06:46 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRslowandswap &raquo;</TD></TR><TR><TD CLASS="quote">that is probally not anyhting to do with the injectors
all i know is i've heard numerous accounts of people running the AFC hack/SMC with dsm injectors and having problems, then the problems mysteriously vanishing when they switch over to RC injectors. i dont know how you could say its not the injectors.
Modified by keebler65 at 2:51 PM 6/1/2003
Old May 30, 2003 | 07:49 PM
niedejb's Avatar
Default Re: (keebler65)
all i know is i've heard numerous accounts of people running the AFC hack/SMC with dsm injectors and having problems, then the problems mysteriously vanishing when they switch over to dsm injectors. i dont know how you could say its not the injectors.</TD></TR></TABLE>
Huh? Switching from dsm to dsm and their problems go away? Confused.
Old May 30, 2003 | 08:17 PM
drjondurst's Avatar
I've got a question.. with a 91 CRX do you have to do any messing with any injector boxes?
Old May 30, 2003 | 09:59 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: (drjondurst)
I know alot of people use DSM and RC injectors but what about Accel, Greddy, and Venom injectors?
Old May 31, 2003 | 08:59 AM
drjondurst's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drjondurst &raquo;</TD></TR><TR><TD CLASS="quote">I've got a question.. with a 91 CRX do you have to do any messing with any injector boxes?</TD></TR></TABLE>
Old May 31, 2003 | 09:07 AM
92sleepR's Avatar
New User
Default Re: Difference: RC440 and DSM450 (KOTSEMOTO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOTSEMOTO &raquo;</TD></TR><TR><TD CLASS="quote">The difference is about $250 retrail list price.</TD></TR></TABLE>
Word
Mike
Old May 31, 2003 | 03:19 PM
drjondurst's Avatar
hmm anyone know the answer to my ?
Old Jun 1, 2003 | 06:56 AM
Turbocivic94's Avatar
No, just install the injectors
Old Jun 1, 2003 | 11:45 AM
Tru Dynamix's Avatar
Default Re: (25 PSI CRX)
i think i heard once that the older honda models already have a resistor box. but not sure what years they start.
also, the obvious answer to this question (differences) is basically the installing issue. dsm's are great injectors and best of all, they are cheap. ($100 for injectors and resistor box shipped usually).
HOWEVER, wiring the dsm's are a BITCH! sure u have a wiring diagram, but u gotta sit there, crimp this, strip that, make sure the right wire is connecting to this and that. it took my dumbass almost an hour to finish the wiring. of course, u save $200 or so dollars. but to top it off, dsm injectors are usually always USED&gt; some are maybe even 10 yrs old. my biggest concern was my injectors didnt fit perfectly, and had to force one in there while the others just slid in easily. had me worried they might pop out while car is on.
ok, all im saying is dsm's are good injectors IF installed corectly and if they are in perfect working condition. now, im the type of guy who loves a peace of mind. so if im spending $3000 already on my turbo set up, i wouldnt wouldnt mind spending $200 more on some brand new, easy fitting, no wiring, will start up the first time injectors but thats just me.
