Difference: RC440 and DSM450
Old Jun 1, 2003 | 11:51 AM
  #26
keebler65's Avatar
Default Re: (niedejb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niedejb &raquo;</TD></TR><TR><TD CLASS="quote">
Huh? Switching from dsm to dsm and their problems go away? Confused.</TD></TR></TABLE>
sry i meant RC's
Old Jun 1, 2003 | 12:42 PM
  #27
Killer_B's Avatar
Default Re: Difference: RC440 and DSM450 (@irborne)
is it absolutely necessary to use the resistor box? why-why not? i have RC 310's now and i am thinking about switching to DSM440-450 injectors with a VAFC. i'm boosting 9-10lbs. is this a wise choice?
Old Jun 1, 2003 | 03:37 PM
  #28
fsp31's Avatar
Default Re: Difference: RC440 and DSM450 (Killer_B)
The "part throttle bucking" has nothing to do with DSM injectors, it's about the AFC hack. Anyone with *any* type of "hack" on the map sensor will experience a little more abrupt on/off throttle, although some people experience it more than others. The reason this is happening is because under deceleration, the Honda ECU cuts the fuel injectors entirely. That's right, no pulses at all. Not even idle. It's an emmission control measure. When the MAP signal has been knocked down 30-40%, the ECU "thinks" the car is decelerating when in reality you may be giving it slight throttle. So, bottom line is abrupt throttle response is just as likely to happen with RC injectors. Try richening up the idle fuel settings some. That worked for me.
Old Jun 3, 2003 | 10:44 PM
  #29
Killer_B's Avatar
*bump*
do i really it or not??
Old Jun 3, 2003 | 11:33 PM
  #30
red_sir's Avatar
Default Re: Difference: RC440 and DSM450 (fsp31)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsp31 &raquo;</TD></TR><TR><TD CLASS="quote">The "part throttle bucking" has nothing to do with DSM injectors, it's about the AFC hack. Anyone with *any* type of "hack" on the map sensor will experience a little more abrupt on/off throttle, although some people experience it more than others. The reason this is happening is because under deceleration, the Honda ECU cuts the fuel injectors entirely. That's right, no pulses at all. Not even idle. It's an emmission control measure. When the MAP signal has been knocked down 30-40%, the ECU "thinks" the car is decelerating when in reality you may be giving it slight throttle. So, bottom line is abrupt throttle response is just as likely to happen with RC injectors. Try richening up the idle fuel settings some. That worked for me.</TD></TR></TABLE>
Thanks for clearing that up, I always wondered what caused it.
Old Jun 3, 2003 | 11:52 PM
  #31
Sonny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killer_B &raquo;</TD></TR><TR><TD CLASS="quote">*bump*
do i really it or not??</TD></TR></TABLE>
Yes. If not, I hope you have a stack of spare ECU's. You'll need them.
Sonny
Old Jun 4, 2003 | 12:03 PM
  #32
boostsohfast's Avatar
Default Re: Difference: RC440 and DSM450 (red_sir)
What are you and some others runnin at idle? I currently have mine set at -38% with the dsm 450's. I had it at -40%, but -38% idles better. For 1k rpms to 4k rpms I have it at -40% still.
racingsoul
May 7, 2006 07:37 PM
aznxphreak
Nov 18, 2003 06:19 AM
EK_vzla
Sep 16, 2003 02:39 PM
DragInteg
Apr 3, 2003 11:49 AM
91hatchcivic
Sep 14, 2002 08:53 AM
