electrical ? for eg cluster, plz read..
i have an eg6 cluster, now the back of the cluster has 3 plugs, the yellow one in the middle is missing on the actual gauge cluster, and when i try to adjust the backlight, it brightness at night stays the same......now i also have my dx gauge cluster which still has the plug connecter in the back, if i remove it from the dx cluster and install it in the eg cluster, will it work for the backlight, or what should i do?
any info is greatly appriciated, thanks for reading!
The extra plug is the dim switch so after the JDM cluster goes in no more dim option. What I did with mines was I set the dim to the way i like it then plug in the eg6 cluster and it should work fine.
wow.....snoop dizzle's crackin me up!
No dimmer on the eg6 cluster.
The extra yellow plug is for airbag stuff. All yellow plugs and wires are
for your srs system. I think you should just sell me your eg6 cluster so
I can get rid of this damn 4dr one.
