NEED HELP! Compression on Pistons are too LOW!
Old May 29, 2003 | 04:20 PM
Killer_B's Avatar
Default NEED HELP! Compression on Pistons are too LOW!
Modified by Killer_B at 2:04 PM 7/10/2003
Old May 29, 2003 | 04:28 PM
Hayasa15's Avatar
Default Re: NEED HELP! Compression on Pistons are too LOW! (Killer_B)
You could get the correct pistons or have your head milled that should raise your compression.
Old May 29, 2003 | 04:34 PM
Killer_B's Avatar
Default Re: NEED HELP! Compression on Pistons are too LOW! (Hayasa15)
i already bought the pistons. wouldn't i have a problem with Valve clearence if i shave the head??
Old May 29, 2003 | 04:38 PM
rpm9100's Avatar
I had the same problem, I used a spoon 2 piece headgasket, as well as had my head shaved.
If you take the head gasket, head and pistons to a machine shop they can get you to your desired cr.
I went from 8.8:1-9.5:1
Old May 29, 2003 | 04:52 PM
boosted92's Avatar
Read what you said again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Killer_B &raquo;</TD></TR><TR><TD CLASS="quote">i ordered a set of 9:1 compression pistons for my GSR block with a B16 Head but instead they sent me pistons for a 9:1 Compression for a Ls/Vtec.
They fucked up on the order. Send the pistons back and get your real pistons, and make them pay for the shipping. You shouldn't have to deal with a setup that you don't want because some tit in their shipping department messed up.
BTW, if you are dead-set on keeping those pistons, I don't see how they would be near 8:1. Pistons for a 9:1, 81MM bore LS/vtec should have a dish of about 7CC's. A 7CC dished piston in your motor would result in around 8.8:1 compression. Not a huge difference, I doubt you'd even notice it on the street, but send them back and get your real ones regardless.
Old May 29, 2003 | 05:02 PM
Killer_B's Avatar
Default Re: NEED HELP! Compression on Pistons are too LOW! (boosted92)
i've had the pistons for a while and didn't realize it until now. i just need to know what i can do with what i have now.
Old May 29, 2003 | 07:03 PM
Hayasa15's Avatar
So why not just put in those pistons and a thinner Cometic headgasket. The new hg will raise you cr a few more points i would expect.
kevin7200
Jan 12, 2015 08:18 PM
jdmdshank
Sep 15, 2007 01:18 PM
canada-civic
Mar 1, 2006 07:50 AM
yellowmonkeyboy
Oct 1, 2004 03:38 PM
B00ST2nR
Sep 22, 2004 02:50 PM
