Turbo spoolin times?
Old May 28, 2003 | 08:27 PM
turbo se's Avatar
Default Turbo spoolin times?
Just wondering what contributes to identical turbos spoolin up at different rates. Does a 3" exhaust have a lot to do with how fast the turbo spools. I have t3/t4 and mine fully spools at about 4500rpm. My buddy has the same size but is in full boost around 3400rpm. So what gives? Im running a drag kit with a 2.25 exhaust, dsm injectors,hondata stage2,etc.. My compression is around 9-1. Does the lower compression have something to do with it? Frankly im lost and would love some suggestions. Im sure the exhaust is a major problem but you guys no more than me. Any help would be awsome. Thanx.
Old May 29, 2003 | 05:46 AM
turbo se's Avatar
Default Re: Turbo spoolin times? (turbo se)
Anyone have any input?
Old May 29, 2003 | 06:37 AM
kamaleon's Avatar
check for leaks
Old May 29, 2003 | 06:49 AM
Speedworks801's Avatar
Exhaust piping diameter, Wastegate adjustment/condition, A/F ratio, timing, fuel octane, the comp and turbine specs (a/r, etc.) of the turbos, the engine's static/dynamic compression, length of exhaust piping, bore size.
I think I probably left something out, but this should give you some idea. I would also check for cracks in the manifold, or leaks in the piping, as well as turbocharger condition/health of bearings.
Happy Boosting!
Old May 29, 2003 | 07:11 AM
ELSpool's Avatar
I just had the same problem. My set-up has the same turbo but I run an internal wastegate, and the stock actuator was open all the time for 9psi...so pick up a smaller actuator and put it on for 6 psi. Now it,s closed and I run a MBC to open at 9 psi. Sppol time went from 4700 to 3900rpm. It's like a totally different car now. If you have an external gate though, different story for ya then.
Old May 29, 2003 | 07:33 AM
bottlefedb18c1's Avatar
compresion does have alot to do with it and you ignition timming also and ex size
Old May 29, 2003 | 07:36 AM
94dxt's Avatar
Default Re: Turbo spoolin times? (Speedworks801)
[QUOTE=Speedworks801]Exhaust piping diameter, Wastegate adjustment/condition, A/F ratio, timing, fuel octane, the comp and turbine specs (a/r, etc.) of the turbos, the engine's static/dynamic compression, length of exhaust piping, bore size.
Old May 29, 2003 | 01:31 PM
turbo se's Avatar
thanx for all the input guys i hope things will be better after the 3" mandrel bent exhaust and the tuning is done.
Old May 29, 2003 | 02:30 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo se &raquo;</TD></TR><TR><TD CLASS="quote">thanx for all the input guys i hope things will be better after the 3" mandrel bent exhaust and the tuning is done. </TD></TR></TABLE>
The 3" should make a HUGE difference. 2.25" is just too small for a turbo app.
SPITVENOM67
Jun 30, 2014 04:20 PM
2ndchirp
May 17, 2009 09:15 PM
JFG Kevin
Jun 9, 2004 06:24 PM
Rhythm Racer
Mar 3, 2003 10:24 AM
KLN
Mar 1, 2002 10:34 PM
