Turbo exhaust
Old Jun 7, 2004 | 10:13 AM
JFG Kevin's Avatar
Default Turbo exhaust
i'm planning to go boost but i have a tie up with what exhaust i should get. i been searching and see that thermal 3" exhaust are pretty loud...i realli like the way the greddy sp2 looks and sounds...but i was wondering is the piping size goin to reduce my power alot.
Old Jun 7, 2004 | 11:25 AM
Mag00n's Avatar
Default Re: Turbo exhaust (aznstyler119)
Whats your setup? How much power are you planning on making? That is important in considering piping size. Im making around 230whp and use 2.5" turbo back. Also you will notice turbo cars as a whole are more quiet than NA.
Old Jun 7, 2004 | 12:04 PM
JFG Kevin's Avatar
Default Re: Turbo exhaust (SICKSOLVTEC-T)
well...i'm doin a gsr turbo...running stock internals....most i'll boost is at 5psi....looking around 240-250whp....
Old Jun 7, 2004 | 12:07 PM
Mag00n's Avatar
Sorry but I think 250whp is a little too optimistic on only 5psi, even on a gsr.
Old Jun 7, 2004 | 12:27 PM
95GSRTT
Guest
Posts: n/a
Bump your compression to like 12.1 or higher and you could do it with 5 psi and a good turbo
Old Jun 7, 2004 | 12:33 PM
iiilgsrlll's Avatar
Default Re: Turbo exhaust (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">Bump your compression to like 12.1 or higher and you could do it with 5 psi and a good turbo </TD></TR></TABLE>
I've seen 270hp at the wheels on 5psi before using a t04x. This was dyno'ed at AEBS in San Diego back in 2000.
Old Jun 7, 2004 | 01:29 PM
rezo's Avatar
Default Re: Turbo exhaust (iiilgsrlll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">I've seen 270hp at the wheels on 5psi before using a t04x. This was dyno'ed at AEBS in San Diego back in 2000. </TD></TR></TABLE>
Yeah it's definitely possible, but how many internal mods and how much tuning did it take to make that much HP on 5 pounds? Was it like a Supra that they turned the boost down on or something o.O
Old Jun 7, 2004 | 01:33 PM
quikB18B's Avatar
Default Re: Turbo exhaust (rezo)
Well if your concerned about loudness, I would wither run a Custom 2.5 " setup or maybe the GReddy peII(2.75")
Old Jun 7, 2004 | 01:35 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rezo &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah it's definitely possible, but how many internal mods and how much tuning did it take to make that much HP on 5 pounds? Was it like a Supra that they turned the boost down on or something o.O</TD></TR></TABLE>
This was on a 95 GSR with stock internals running with basic inline pump/12:1 fmu 3inch exhaust. This was back in the days before Hondata was really mainstream. There really wasn't much tuning involved.
Old Jun 7, 2004 | 03:11 PM
poid's Avatar
i run a full 3" exhaust with high flow cat, resonator and Magnaflow muffler. Its a LOT quieter than i thought it would be, when cruising its pretty much as quiet as the stocker.
Old Jun 7, 2004 | 04:35 PM
brickonwheels's Avatar
poid, how much did it cost you total to run your exhaust? That is my plan right now.
Old Jun 7, 2004 | 04:39 PM
2000GSRT's Avatar
Default Re: (poid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poid &raquo;</TD></TR><TR><TD CLASS="quote">i run a full 3" exhaust with high flow cat, resonator and Magnaflow muffler. Its a LOT quieter than i thought it would be, when cruising its pretty much as quiet as the stocker.</TD></TR></TABLE>
I'm running the exact same configuration as you are except mine is 2.5" all the way back. Made 254 hp and 187 tq @ 10psi
I think it's quiet compared to lot's of other hondas I've heard with exhausts. A 3" probably wouldn't be much louder, but I would imagine that it could get slightly annoying at times.
Old Jun 9, 2004 | 05:25 PM
kamaleon's Avatar
Default Re: (poid)
I run 3" turbo back with no cat and magnaflw turbo exaust.. its too loud! im goign to add a 3" highflow cat and change teh muffler cuz its unbareable after a while.. this is in a shoc.
What 'quiet' 3" mufflers do you guys know about?? I just started the search tonight and im not fining anything good, al i find is the junk on ebay for $10-$40
Old Jun 9, 2004 | 06:24 PM
Ever think of adding a resonator?
vinceg143
May 18, 2009 12:13 AM
ThatsTheTruth
Apr 25, 2006 09:57 AM
downeyballz
Dec 28, 2004 02:40 AM
tegon-gsr
Dec 14, 2004 06:31 PM
rMak
Jun 12, 2004 11:25 AM
