got mah h22 ej done!
...took me a while but i got her done!...vtec still not working....but still pretty dam quick! my final bout was eld code 20 and the dreadd o2 code 41!...all endd with a 7.5a fuse that was blown! ahhahahahah i own you!...ill see if i can get some pics up for you guys!
Good news. But remember 41 is not an O2 code but a heater code. make sure you are getting voltage to the other black wire.. Otherwise you car will be in safe mode and will be slower than it may seem now.
im not getting any codes now!? only 21 when i hit vtec!? oil level is fine...i do have a dent in my oilpan? other than that i do get a 43 every now and then and my car is running really rich!?
Check your wiring on the vtec solenoid.. I think that one only has one green wire. Make sure its going to the right place. And I think 43 has to do with your fuel.. Have that checked out as well..
43 is fuel supply system...in diagnosis it says that the o2 can cause this...which makes sense..other than that i do have a 255 pump in place of the what would be the stock lude 205..i dont think this would have too many adverse effects though? ill be doin some tunin here in the next couple days..ill see how it goes.
civicguy395
Oct 30, 2012 03:52 PM
daredeezy619
12
Mar 6, 2008 05:41 AM
Jason kiDD
Jul 17, 2002 11:25 AM
