does anyone have experience with naval jelly?
Old May 27, 2003 | 10:06 PM
216.226.142.95:27016's Avatar
Default does anyone have experience with naval jelly?
i used some to remove rust from a metal piece and it worked! only problem is that when i wash the jelly off with water, like directed, some rust, like on brake rotor, forms on the surface. does anyone have any tips or know how to prevent this?
thanks
Old May 28, 2003 | 04:36 AM
B Speed's Avatar
Default Re: does anyone have experience with naval jelly? (216.226.142.95:27016)
you're not supposed to wash it off. I don't know what directions you read. You're supposed to let it dry, then primer over it with rust fighting primer.
Old May 28, 2003 | 05:15 AM
MTK Kommander's Avatar
Default Re: does anyone have experience with naval jelly? (B Speed)
my rotors get little rust spots every time it rains. i just go drive and the spots go away.
Old May 28, 2003 | 09:48 AM
the directions came straight from the back of the bottle. it says wash it off with water. it did not say anything about letting it dry and paining over it. doing that will just leave the rust between the metal and paint even if naval jelly dissolved it.
Old May 28, 2003 | 10:04 AM
ScaleExtric's Avatar
Default Re: does anyone have experience with naval jelly? (MTK Kommander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MTK Kommander &raquo;</TD></TR><TR><TD CLASS="quote">my rotors get little rust spots every time it rains. i just go drive and the spots go away. </TD></TR></TABLE>werd up..thats all i do
Old May 28, 2003 | 01:51 PM
Default Re: does anyone have experience with naval jelly? (ScaleExtric)
I am NOT talking about BRAKE ROTORS AT ALL, i just used that as an example of what type of rust is forming. im cleaning and taking of rust on a metal panel, to be more exact the bucket metal that holds the foam on del sol seats.
anyone at all have experience working with naval jelly to prevent the rust from forming?
Old May 28, 2003 | 01:59 PM
fsck3r's Avatar
quakserver? You play CS?
Old May 28, 2003 | 03:15 PM
Mt3c's Avatar
did you read the rest of the instructions? If i remember correctly, it says to apply primer or some protective coat to prevent rust from reappearing after nave jelly is removed.
Old May 30, 2003 | 03:13 AM
DCStreetHtch's Avatar
Default Re: does anyone have experience with naval jelly? (Mt3c)
the last part of that quote in your sig is the best....
"... and our country is being run by guys by the name of Dick, Colon and Bush."
-Bryan-
GrayT
Sep 15, 2004 11:40 AM
Marcos
Jul 21, 2004 11:45 PM
es_squared
Jun 21, 2004 07:06 PM
SteveeeO
Feb 21, 2003 07:30 PM
GSpeedR
Mar 31, 2002 01:53 PM
