Infamous Header Rattle
Old May 26, 2003 | 04:46 PM
PolyPill's Avatar
Default Infamous Header Rattle
Posting this here to get more people to read it, I also posted in the itr section.
I installed a DC Sports 4-1 header on my 2k1 Integra GSR and now I've got that damned header rattle around 3k rpms. VERY VERY annoying!
I thought it might be the heat shield by the cat, since that is the area it sounds like it is coming from, but unless the cat is moving a good 2 inches there's no way it's hitting that. There was no rattle with the stock header.
The clearance on the oil pan concerns me, it's about 2mm, seams like a very likely place to be hitting, but it doesn't sound like it is coming from there and if it were I would think it would be a very common problem. And I have no clue how that would be fixed.
Everything I read seams to be about older itrs with a stock header, it has been rattling since I put the thing on when it only had 20k miles. Any ideas? or should I just give the people at DC Sports a punch in the stomach?
Old May 27, 2003 | 08:18 AM
PolyPill's Avatar
Default Re: Infamous Header Rattle (PolyPill)
Bump
Old May 27, 2003 | 08:54 AM
ultimatehonda's Avatar
Is your donut gasket still good? May want to try changing the spring bolts to normal bolts.
Old May 27, 2003 | 08:56 AM
AWD: Jeff's Avatar
Default Re: Infamous Header Rattle (ultimatehonda)
r u sure u even have the o ring gasket on that header, cuz a friend of mine forgot, and we just poped one right on there, and problem solved, or u can go with what ultimatehonda said
Old May 27, 2003 | 09:09 AM
Quad-Damag's Avatar
Default Re: Infamous Header Rattle (Dohc93hatch)
Mine Rattels due to the stock header holder, it's a metel thing that touchs the exhaust and when it's moving it raddels
Old May 27, 2003 | 10:15 AM
PolyPill's Avatar
I know we didn't forget to put the gasket on and I remember it was in good condition, the car only had 20,000 miles on it when I put the header on.
It is bolted to the bracket firmly, I checked it a million times, ok 3 times.
When I get home I'mm going to take all the heat shielding off even it I don't think it is hitting. It was suggested that sometimes it rattles just because it sucks.
Old May 28, 2003 | 07:47 AM
AWD: Jeff's Avatar
maybe its one of the heat shields, cuz i took off all my heat shields around the cat and piping area and there was no more rattling.
Old May 28, 2003 | 02:29 PM
locass316's Avatar
check ur 02 sensor.. might be loose..use lock tight
Old May 28, 2003 | 10:24 PM
rhettster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolyPill &raquo;</TD></TR><TR><TD CLASS="quote">I know we didn't forget to put the gasket on and I remember it was in good condition, the car only had 20,000 miles on it when I put the header on.
That bracket bolts to the block on the other end -- I had a rattle because one of those bolts had gotten lose.
Old May 28, 2003 | 11:48 PM
Outrun's Avatar
Default Re: Infamous Header Rattle (rhettster)
Retorque all the bolts.
Old May 29, 2003 | 06:04 AM
B16Ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda &raquo;</TD></TR><TR><TD CLASS="quote">Is your donut gasket still good? May want to try changing the spring bolts to normal bolts. </TD></TR></TABLE>
thats what did it for me
Old May 29, 2003 | 05:44 PM
00CIVICwB18C1's Avatar
Default Re: Infamous Header Rattle (B16Ej1)
check for rocks above the heat shield. That's what was rattling in my car until i got under it and started troubleshooting.
Old May 30, 2003 | 04:12 AM
JDMlyfestyle's Avatar
Might wanna check to make sure the header bolt didnt come loose. my buddy didnt tighten his enough and now he has the annoying rattle
suken19
May 14, 2005 03:30 AM
rewhipple
Apr 6, 2005 09:22 AM
PolyPill
Jan 6, 2005 10:22 PM
Brasspremier
May 3, 2003 04:06 PM
keck
Feb 26, 2002 05:02 PM
