Infamous Header Rattle
Posting this here to get more people to read it, I also posted in the itr section.
I installed a DC Sports 4-1 header on my 2k1 Integra GSR and now I've got that damned header rattle around 3k rpms. VERY VERY annoying!
I thought it might be the heat shield by the cat, since that is the area it sounds like it is coming from, but unless the cat is moving a good 2 inches there's no way it's hitting that. There was no rattle with the stock header.
The clearance on the oil pan concerns me, it's about 2mm, seams like a very likely place to be hitting, but it doesn't sound like it is coming from there and if it were I would think it would be a very common problem. And I have no clue how that would be fixed.
Everything I read seams to be about older itrs with a stock header, it has been rattling since I put the thing on when it only had 20k miles. Any ideas? or should I just give the people at DC Sports a punch in the stomach?
Re: Infamous Header Rattle (ultimatehonda)
r u sure u even have the o ring gasket on that header, cuz a friend of mine forgot, and we just poped one right on there, and problem solved, or u can go with what ultimatehonda said
I know we didn't forget to put the gasket on and I remember it was in good condition, the car only had 20,000 miles on it when I put the header on.
It is bolted to the bracket firmly, I checked it a million times, ok 3 times.
When I get home I'mm going to take all the heat shielding off even it I don't think it is hitting. It was suggested that sometimes it rattles just because it sucks.
Re: Infamous Header Rattle (PolyPill)
maybe its one of the heat shields, cuz i took off all my heat shields around the cat and piping area and there was no more rattling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolyPill »</TD></TR><TR><TD CLASS="quote">I know we didn't forget to put the gasket on and I remember it was in good condition, the car only had 20,000 miles on it when I put the header on.
That bracket bolts to the block on the other end -- I had a rattle because one of those bolts had gotten lose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultimatehonda »</TD></TR><TR><TD CLASS="quote">Is your donut gasket still good? May want to try changing the spring bolts to normal bolts. </TD></TR></TABLE>
thats what did it for me
