update on the rattle
Old May 2, 2003 | 01:55 PM
Brasspremier's Avatar
Default update on the rattle
i read that to get rid of the 3k-4k rpm rattle, you remove the heatshields. so far i've taken off the two on the cat and the one facing you on the header. it still makes the sound however. i noticed there is another headshield behind the header and there is some that runs along the rest of the exhaust. did i just miss the heatshield that usually causes the problem?
Old May 2, 2003 | 02:16 PM
mickey513's Avatar
Default Re: update on the rattle (Brasspremier)
If you have a 94 or 95gsr, it's the HEADER. The be exact, if you have a stock header, the rattling is coming from the bottom part of the header (a-pipe) area. I had the same problem on my 94gsr, rattling around 3k-4k rpm. Took off all the head shield on the cat and the two on the exhaust manifold (header) and it still rattled.
I fixed it by buying a header off a 96gsr.
Many people have had this rattling problem. It seem as if though there was a design defect in the 94-95 stock exhaust manifold.
Old May 2, 2003 | 03:18 PM
dohc-nyne's Avatar
i have this problem on my 99 ls....but im not sure exactly wut it is....i have dc headers though....stock cat
Old May 2, 2003 | 04:54 PM
damn, so it is the header then... i was hoping for the easy and cheap route of it... oh well, guess gives me excuse to get the jdm itr header and rest of exhaust
Old May 2, 2003 | 05:08 PM
WiggiE's Avatar
New User
Before you buy anything do this first. Jack your car up. Get someone to go rev your engine up to the rpm where the rattle is the loudest. Grab a broomstick and start pushing on the heatshields until you stop the rattle. That heatshield is your problem. Just remember to not get under your car while running.
Old May 2, 2003 | 05:20 PM
Default Re: update on the rattle (WiggiE)
bushing on the heatshields? i've taken off all the ones where the noise is coming from
Old May 2, 2003 | 11:05 PM
any other opinions?
Old May 3, 2003 | 12:59 AM
Havokmkr's Avatar
he said pushing on the heatshield. Your header might be cracked.
Old May 3, 2003 | 04:14 AM
ebelp's Avatar
Default Re: update on the rattle (Havokmkr)
I had this problem also. I remove every heat shield on my car except for one. It's part #6 in this diagram. You can't remove it unless you take off the entire exhaust manifold. So just get an aftermarket header and be done with it.
Old May 3, 2003 | 06:39 AM
DR3AM's Avatar
Yeah, it could be a crack somewhere. I had the same notorious rattle and after checking all the heatshields I found nothing.
Then, I noticed that there was a crack where the pipe and resonator connect. I had it rewelded and *poof*, the rattle was no more.
Old May 3, 2003 | 06:43 AM
ragejed's Avatar
Default Re: update on the rattle (Gizzzer98)
you guys still use a header? bah.. i take out what ever rattles
Old May 3, 2003 | 02:05 PM
Default Re: update on the rattle (ragejed)
yea, i missed #6 on that picture. i guess jdm 4-1 for me, heh... just gotta figure that out before i buy anything
Old May 3, 2003 | 03:57 PM
ucb's Avatar
ucb
i had a 96 that had the rattle, so its not just 94-95
Old May 3, 2003 | 04:06 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: update on the rattle (UCBGSR)
I had the rattle once, took it into the dealership and they got rid of it for $40.
Said something about the b pipe rubbing against the chasis.
JDMBukLau
22
Sep 27, 2012 07:49 PM
PolyPill
Jan 6, 2005 10:22 PM
SCGsROCK!
Apr 23, 2004 10:58 PM
cyrk007
Apr 16, 2003 05:35 AM
