Auto to Manual Conversion: b16 Type R Swap
How difficult and costly is it to convert an automatic HB to a manual? I have a 98 Civic that I am looking to turn into a road race car but I'm not sure what I'm looking at in terms of cost. Can you guys give me ideas and tips? Thanks
Loc
Loc
My firend coverted his D16y7 to a B18b and it cost him around 2 days of time, and about 2300
and he got his engine for 1700 and clutch and flywheel and intake and wires and plugs.
Me and Him picked up most of the stuff from junk yards, you need to pick up the pedels and all the 5 speed stuff, Converting from a D to a B will be almost more then, just chaning from a D to a D, but just swaping over tranmissions.
It's hard work, but his car is so much faster then my automatic
Im confused regarding the pedal set up. Will I have to locate a 5-speed set up from a junk yard or what? I guess Im more concerned about the little things. The swap itself Im not to worried about, just getting the pedal set up done right as well as the gearing and what not. I dont know that much about the engine swaps much. Thanks
Loc
Loc
U can't use ur automatic pedel's duh, u have to buy some for your car. I forget what he used, i didn't do the swap with him, i just saw the before and after, and helped him get the finshing stuff, he go the pedels off some guy for free, and thats when he decided he wanted to do the swap. they are off a Civic Si, if that helps
Yea that does actually..the engine swap wont happen till next summer. This summer is suspension and braking with some weight reduct work. Thanks a lot.
Loc
Loc
http://www.crxsi.com/resources...7.htm
http://members.tripod.com/imports_r_us/civic.html
http://hybrid2.honda-perf.org/faq/section02.html
that might get u on the right track
you have to change all your pedals to the 5 speed all will bolt right in, and run your factory clutch lines you do not have to change the brake master cylinder and install your pedals.the clutch switch to start the car will have to be ran from the plug of the auto shifter's nuetral safety switch. Then you have to jump the wires for the reverse switch. Is simple just a little time.and whatever trans
Lx Civic 99
Jan 2, 2014 05:56 PM
98savage
Jul 15, 2007 05:38 AM
cozmo2312
Aug 25, 2003 07:54 PM
