intank pump w/ fmu a no no?
Old Jul 12, 2001 | 05:47 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default intank pump w/ fmu a no no?
i guess this was addressed somewhere. i heard it will lean out. does this mean the factory pump will work better and my purchase for the 255 intank was a waste? then do i need to use an inline or not? i have 310 injectors if they mean anything in this equation.
Old Jul 12, 2001 | 05:55 PM
Smashback's Avatar
Default Re: intank pump w/ fmu a no no? (loturbohybrideg)
Which pump did ya get? As long as you get a high pressure 255 you should be fine at somewhat reasonable boost levels.
Old Jul 12, 2001 | 06:01 PM
Default Re: intank pump w/ fmu a no no? (mplex2000)
it's the holley. i heard bosch was the one to get but too late for that. i don't know if it's high pressure, i assume it is? and yeah, i won't be boosting more than 7-8 lbs. it peaks now at 6 and that is plenty for my fully gutted hatch. are those levels ok? do i only need to worry about that problem on higher boost app's? thanks for any more info.
vietxdragon
Sep 25, 2006 06:24 PM
itr449
Feb 12, 2003 08:12 PM
KevronsEG
Jul 31, 2002 07:09 PM
Hybrid
Jul 7, 2002 02:21 PM
millertime
Oct 2, 2001 09:05 PM
