best way to plug a coolant bypass inlet?
I'm not going to need the small bypass inlet on the thermostat housing. The little one on the left in the photo.
What's the PROPER way to plug it? Can I pull the brass fitting out and tap the hole for an NPT bolt? How would I get that fitting out? Is it just pressed in there?
They sell water hose endings just for this purpose at every auto store for under 5 bucks. Pep boys, autozone, advanced, etc etc, just rubber endings and then add a clamp to it you're set.
I think you could buy a obd 2 housing.
THis goes to the upper rad hose housing right.
What is it for on obd 1 cars, since obd 2 cars dont even use it.
I read that its a breather heater for the valve cover to intake tube. THat why the valve cover breater hose and that coolant hose are connected by those metal tube that are together.
