Fuel problem???Help?
Old May 22, 2003 | 01:53 PM
civicspeed77's Avatar
Default Fuel problem???Help?
Heres the problem! I have a 1990 Honda Civic hatch a standard 4 speed. I was driving one dayand the ride just gave out. The car felt as if it wasn't getting fuel. So I replaced the fuel pump, filter, injectors, spark plugs and wires. I was wondering if I need or if the problem is the fuel sending unit???
Old May 22, 2003 | 02:15 PM
APEX CRX's Avatar
Default Re: Fuel problem???Help? (civicspeed77)
so it cut out and won't restart? does it crank over real strong with no hesitation?
Malgerus's Avatar
Could be a lot of things. Did you check for spark? Get a fuel guage at the fuel filter and check for pressure.
Old May 22, 2003 | 02:17 PM
APEX CRX's Avatar
oh also make sure it's not the timing belt. if it cranks take the oil cap off and see if the valves/springs move with someone else cranking the ignition. i was driving my 89 crx si one day and the timing belt broke and it had the same symptoms. luckily didn't bend anything
Old May 27, 2003 | 12:13 PM
Well I replaced the distributor and it started but shut off again. I wonder if it has to do with the TPS on the throttle body?
bluejcivic
May 20, 2010 04:21 AM
johnny090881
Jun 7, 2009 10:56 PM
bluelude2.3
May 25, 2007 11:58 AM
lbjoe
May 22, 2003 04:41 PM
Tij
Sep 2, 2002 04:49 PM
