How to advance your timing?
Old May 21, 2003 | 05:48 PM
spencedogg's Avatar
Default How to advance your timing?
How do you advance your timing and how much to do it with no engine harm?
Old May 21, 2003 | 06:09 PM
Shift!'s Avatar
Default Re: How to advance your timing? (spencedogg)
The only real way to do it is with a timing light. But basically you turn your distributor and keep a light hooked up to adjust it. Also I think you need to override your knock sensor when doing this so that your ECU simply doesnt retard it back to normal.. Im not 100% sure on that tho.
You can also use timing gears, which give you better control of valve timing. However its really not recommended to just shoot from the hip and not use a light.
Some people say to turn your distributor little by little, then drive your car after every adjustment. Drive your car up a hil and put it in a high gear (say 4th gear going up a hit at say 25mph) and listen for pinging... if you hear it, then back off your dist an increment. How big those increments are is up to you.
ericliley1993
Feb 12, 2018 03:56 PM
adip315
Jan 28, 2007 04:48 AM
sheBangZ
Feb 5, 2006 07:15 AM
johnbrooke86
Aug 23, 2004 04:49 PM
turbo Si
May 7, 2002 12:59 PM
