if u just build ur motor would u ?
Old May 21, 2003 | 04:23 PM
Black DC2's Avatar
Default if u just build ur motor would u ?
i just build my gs-r jrsc motor and white smoke is coming out the valve cover breather is it because the piston rings r not seated yet or did i **** up something also i have the endyn catch can
Old May 21, 2003 | 05:50 PM
cnydelSolHybrid's Avatar
Default Re: if u just build ur motor would u ? (Black DC2)
if you used syn blend oil the rings wont seat. Use a Mineral Base 20w50 for 1000 miles then dump it. and you should not boost on the engine till the rings have seated
Old May 21, 2003 | 07:16 PM
Black DC2's Avatar
Default Re: if u just build ur motor would u ? (cnydelSolHybrid)
i haven't boosted yet only hace 100 miles on the motor it throws out smoke at idle just want to see if this is normal and i used 10w 30 regular oil
Old May 22, 2003 | 11:26 AM
get a 20w50. and get in and drive. if the smoke persists its a bad ring job and its gotta come out.
kidd_drastic
Jul 20, 2006 04:12 PM
Sassafrass
May 19, 2006 04:47 AM
1SlowSi
May 20, 2005 10:01 AM
Collateral
Mar 14, 2005 10:39 PM
tominos
22
Feb 18, 2003 08:55 PM
