how do i reset my comp?
start, shut down, restart...
or, are you looking for a real reset?
In that case go to start, programs, ms-dos-prompt... The type" format c: "and hit y
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by musclefella »</TD></TR><TR><TD CLASS="quote">You can take the ecu fuse out for a couple of minutes to.</TD></TR></TABLE>
I dont know if there is an actual ECU fuse, but you can reset your ECU by pulling the clock fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Vtec 23 »</TD></TR><TR><TD CLASS="quote">
I dont know if there is an actual ECU fuse, but you can reset your ECU by pulling the clock fuse.</TD></TR></TABLE>
hahaha, i think thats funny that the clock fuse resets the ECU
i know there is one on 4th gens, its in the eng. compartment fuse box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smslude »</TD></TR><TR><TD CLASS="quote">Disconnect the negative battery terminal for a few minutes..</TD></TR></TABLE> No fuses required
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec »</TD></TR><TR><TD CLASS="quote">
i know there is one on 4th gens, its in the eng. compartment fuse box</TD></TR></TABLE>
Yeah its the 10a clock fuse, it controls the clock, stereo, ECM (ECU), transmission control module and some other stuff. I guess you can call the ECU fuse.
OpTiX619
May 14, 2005 10:05 PM
