Is anyone using a snap in kit with their harnesses?
Old May 20, 2003 | 11:21 AM
IGGY's Avatar
Default Is anyone using a snap in kit with their harnesses?
I just purchased a snap in kit for my harnesses and i was wondering how you intalled them.
What i was most concerned about was how to tighten them do they are torqued correctly. here is what mine look like.
Old May 20, 2003 | 12:32 PM
GRM Scott's Avatar
25 Year Member
Default Re: Is anyone using a snap in kit with their harnesses? (IGGY)
what mounting points are you going to be using? stock belt points? drilling thru frame with backing plates? if you're gonna use the stock points, you might want to get some of the longer shank eyebolts. check out my install, hope it helps. As for torque, hand tighen, then go a bit tighter with pliars or something...not too much, not too little
http://www.sandmracing.com/ssabelt.html
Old May 20, 2003 | 01:23 PM
IGGY's Avatar
Default Re: Is anyone using a snap in kit with their harnesses? (Aleph)
I just bought this Gator Grip socket, so i can use the proper torque settings on the eye bolts. And yes, i did order two extra long eye bolts.
Old May 20, 2003 | 01:26 PM
Phoenix_ITR's Avatar
i usually just hold the eye-bolt with a screwdriver and then torque the nut on the other side down. works for me...
-tony
Old May 20, 2003 | 01:29 PM
IGGY's Avatar
Default Re: Is anyone using a snap in kit with their harnesses? (delinquent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delinquent &raquo;</TD></TR><TR><TD CLASS="quote">i usually just hold the eye-bolt with a screwdriver and then torque the nut on the other side down. works for me...
-tony</TD></TR></TABLE>
i would do that, but you really can't on the stock place.
GSRinmyCRX
Apr 8, 2009 09:16 PM
invisible
Apr 10, 2007 03:19 PM
Si Shane
Dec 22, 2005 11:46 AM
1998teg
Jan 1, 2005 01:27 PM
rubens
Jun 9, 2003 12:40 PM
