header install ?
Old Jan 1, 2005 | 12:49 PM
1998teg's Avatar
Default header install ?
i am going to be putting my comptech header on my integra and was wondering if a torque wrench or an air gun would be best to get the rusted bolts offmwithout stripping them or breaking the nut. if you have experience witht his please fill me in.
Old Jan 1, 2005 | 12:56 PM
Padawan's Avatar
Darth ModerVader
Default Re: header install ? (1998teg)
You should never use a torque wrench to loosen stuck bolts, but an impact gun might be helpful for the bolts at the cat. I'd also suggest soaking all of the nuts/bolts with PB Blaster before attempting to remove them.
Old Jan 1, 2005 | 01:00 PM
IVI's Avatar
IVI
Default Re: header install ? (Padawan)
^ right. you should never use a torque wrench to open bolts. its only used to torque.
i would use an impact gun only on the cat. i dont think it would be a good idea to use it where it meets the head. just use a wrench, make sure you use pb or wd-40.
Old Jan 1, 2005 | 01:22 PM
1998teg's Avatar
Default Re: header install ? (IVI)
so a socket wrench would be my best bet then? and if anyone knows, how likely is it that i will strip or break a bolt?
Old Jan 1, 2005 | 01:27 PM
98BlackTeg's Avatar
I just twisted the bolts until they broke. Then again I had new hardware to put in.
Tong.Y
32
Feb 1, 2011 02:05 PM
blackccoupe
Sep 23, 2010 08:13 PM
user 98292739
Apr 1, 2005 08:09 PM
rubens
Jun 9, 2003 12:40 PM
canuckr
Sep 23, 2001 10:59 PM
