94 civic dx B15B7 turbo question
Old May 20, 2003 | 10:43 AM
94_civic_guy's Avatar
Default 94 civic dx B15B7 turbo question
I can't find any turbo kits made for a 94 civic dx. I have the stock 1.5L in the car and have ben wanting a turbo. If there isn't any kits, does anyone know how to possibly make a custom kit. Any info would be helpful.
Old May 20, 2003 | 10:50 AM
JaeOne3345's Avatar
Default Re: 94 civic dx B15B7 turbo question (94_civic_guy)
its called d15b7.
and any 1.6L sohc turbo kit would bolt up. but keep the boost low and make sure its fueled. d15 rods are pencils.
Old May 20, 2003 | 10:56 AM
Default Re: 94 civic dx B15B7 turbo question (JaeOne3345)
my bad about the D15B7. was a typo. thanks for the help
Old May 20, 2003 | 11:06 AM
SloCivicHMM's Avatar
Greddy makes the SOHC kit...5psi is good.....yes the rods are pencils, but you can stick LS rodss in but notchin the block...I also heard that vx rods are bigger and can with hold a bit more, also look up other stock D series pistons to drop compression for higher boost.....
D series Powa!! With proper boost and tuning you can run 8-10lbs of boost depending what condition the motor is or was in..
Old May 20, 2003 | 12:07 PM
b16ahybrid's Avatar
Default Re: 94 civic dx B15B7 turbo question (SlowCivicHmm)
[QUOTE=SlowCivicHmm] also look up other stock D series pistons to drop compression for higher boost.....QUOTE]
The d15b7 has 9.2:1 compression, goingany lower is pointless. I ran about 5psi on my old engine, with no fuel managment, it was a very ver very forgiving engine, It had 100k when i boosted it and 120k when i swapped it out. It now has over 150k on it and still runing strong in my buddy's civic.
the rods are pencil thin i wouldn't push them with anything more then about 5-6psi max.
Any d-series kit will bolt rite up (greddy would be good) get a 92-95 greddy sohc ex/si kit. or even a drag or revhard.
Old May 22, 2003 | 09:43 AM
Default Re: 94 civic dx B15B7 turbo question (b16ahybrid)
Does anyone know how much i could get a greddy turbo kit for. I only have like 800 bucks. Also, does the greddy kit come with a BOV.
thanks for the help
Old May 22, 2003 | 09:49 AM
no bov or intercooler....they range from 1200 to 1600 brand new.....depending wehre you get it you can get a bov included as well as a few extras...
used they range from 600 to 1400.......
Old May 22, 2003 | 11:10 AM
Pritos's Avatar
New User
https://honda-tech.com/zerothread?id=506789
this will fit your b7.
Old May 22, 2003 | 12:49 PM
B.'s Avatar
B.
400 HP Club
Default Re: 94 civic dx B15B7 turbo question (Pritos)
the d15b7 that i had in my car before the swap kicked ***, well sota. I ran a 75 shot zex in that motor for 5 months, around 2000k and it ran 14.70 at 98 mph. but the everyday power was nothing like the b16a2 that i have now. If I was you, the money that you we end up putting into the 1.5 after turbo would be better of spent putting in the b16 or b18, and you will get better power. like i said I ran a 14.70 was my best on a 75 shot, all motor b16a2 with ITR cams and LSD 14.22 un tuned.......... just a thought.
Old May 22, 2003 | 12:50 PM
Nextelbuddy's Avatar
Default Re: 94 civic dx B15B7 turbo question (THE B)
hey that last setup is the same as mine im doing on saturday
JZs15
Feb 26, 2009 03:21 PM
Tommyed2323
Jan 16, 2008 05:56 PM
S@nt0s
17
Jul 6, 2003 05:19 PM
fEAR9
May 18, 2002 06:10 AM
riceboy17
Jan 29, 2002 12:26 PM
