EG Turbo Question
Old Jan 15, 2008 | 09:19 PM
Tommyed2323's Avatar
Default EG Turbo Question
I have a 94 Civic SI SOHC Turbo, i got some YCP Pistons (Low compression) With egal rods. i have not put them in. im boosting 8 PSI, my question is... Will i gain or loose HP if i instal these pistons? if i will loose HP what could i do to gain Major HP?
Old Jan 15, 2008 | 09:25 PM
D17alltheway's Avatar
Default Re: EG Turbo Question (Tommyed2323)
they're low compression for a reason... so you have the availibility to turn up the boost
Old Jan 16, 2008 | 04:37 AM
Schister66's Avatar
Man U FTW
Low compression pistons allow you to run more boost (aka make more power) on a certain grade fuel. If these YCP's are similar to stock (cast pistons) then i wouldn't go absolutely crazy with the power goal because they'll have the same failures as stock, which are the ringlands. There is a trade-off to lower compression. You're going to have slower off-boost acceleration with a lower static compression, but that is combatted by the ability to run more boost in the upper rpms.
Old Jan 16, 2008 | 04:31 PM
Default Re: (Schister66)
i know about boosing more but the thing is what will i need to do to insure that im not gonna blow the motor up or how much boost could i push? do i need to build my head?
Old Jan 16, 2008 | 04:32 PM
Schister66's Avatar
Man U FTW
Dont expect much more than 300whp and you'll be fine...also the stock head will work for your needs.
Old Jan 16, 2008 | 04:36 PM
Manny86's Avatar
i have those in my car with 1500 miles na and the car runs fine the only thing is the car sounds like a jetta tdi so if you think you spun a bearing or got a bad valve adjustment dont worry
Old Jan 16, 2008 | 05:56 PM
blwn95civic's Avatar
Default Re: EG Turbo Question (Manny86)
a spun bearing sounds nothing like a bad valve adjustment
gorillaglue#4
Apr 27, 2017 06:48 PM
trytomake
Dec 8, 2008 11:30 AM
92civtegra
Aug 15, 2007 08:26 PM
RTst92
Mar 5, 2006 01:56 PM
7rrivera7
Apr 20, 2004 03:46 AM
