D16 turbo
Old Feb 26, 2009 | 06:00 AM
JZs15's Avatar
New User
Default D16 turbo
Im looking at some turbo kits for my d16 and was wondering what mods do u need first befor you can throw on a tubo.
Old Feb 26, 2009 | 07:16 AM
90blackcrx's Avatar
Default Re: D16 turbo
Depends on how much you wanna boost. You can run lower boost on a stock d series engine an be fine, or you can upgrade the rods, and pistons and turn the boost up.
Old Feb 26, 2009 | 07:34 AM
Schister66's Avatar
Man U FTW
"Turn the boost up" is a bad way to put it. For new people, that's merely going to blur the line between boost pressure and power creation.
OP: read the FAQ at the top of the FI forum. It will answer a lot of the questions you may have. The short and sweet answer is that your stock D, with the right parts and a good tune, will be safe in the 220-240whp range on pump gas**. After reading through the FAQ, make another thread and ask what remaining questions you may have...
Old Feb 26, 2009 | 07:51 AM
ryan1's Avatar
lower/normal boost levels just add the normal turbo bits.
high hp numbers build it.
Old Feb 26, 2009 | 02:47 PM
ringo's Avatar
New User
vitara pistons and eagle rods work well for the $$. also upgrade your valvetrain and you should be good. then upgrade your fuel system and engine managment
Old Feb 26, 2009 | 03:21 PM
fjt's Avatar
fjt
But Vitara pistons and Custom D16 I beams work even better...
bosstedb18b
Feb 27, 2010 04:23 AM
ToTriggerHappy
12
Feb 12, 2010 11:55 AM
Headlessmunky
May 8, 2008 08:37 PM
X2BOARD
Jun 18, 2003 10:14 AM
99SilverEx
Jul 6, 2002 11:28 AM
