Retard timing with TUNED ECU ?
Old Jul 11, 2001 | 11:21 AM
BlackGSR's Avatar
Default Retard timing with TUNED ECU ?
I have my base timing set at 18 with the stock ECU. I'm about it install a tuned ECU (work with the Todas). Should I retard my base timing back to 16 - or keep it at 18?
This is a GodSpeed ECU.
Old Jul 11, 2001 | 12:47 PM
slug's Avatar
New User
Default Re: Retard timing with TUNED ECU ? (BlackGSR)
Nope... leave it at 18. With stock compression you won't have any problems with detonation.
Old Jul 11, 2001 | 01:21 PM
Dropspeed's Avatar
Default Re: Retard timing with TUNED ECU ? (NAspecVX)
I would ask Dan @ Godspeed, Mugen recommends setting the timing at 16 degree when using there E.C.U.
Mattj
Old Jul 11, 2001 | 05:34 PM
b16a2antsi's Avatar
New User
i am running Dan's ecu and my timing is set at 18.
Old Jul 11, 2001 | 05:58 PM
Dipshit Dan's Avatar
Default Re: Retard timing with TUNED ECU ? (b16a2ANTsi)
I recommend 16 degrees to be safe. You can advance if you find there is benefit but usually there isn't and you risk chance of detonation in certain situations.
wilsel
Mar 23, 2005 05:37 PM
DerangedEG
Jan 23, 2003 12:40 PM
SpeedracerS4
Jan 27, 2002 10:57 PM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
