00 B16A2 in a 95 EX coupe final checklist before swap....
I am helping a friend do a 00 B16A2 USDM swap in his 95 EX coupe, I want to make sure that we have/know all of the parts we need before we get started. Please double check my list and make sure that I am correct in the parts we need. The EX is a 5 speed from the start (thank God!) Here we go...
1.) Front tranny mount, front AC mount, driver side mount, driver side bracket, and passenger side (tranny) mount from 94+ integra GSR.
2.) Rear mount from 99-00 Civic Si? ( I am unsure of this.)
3.) 99-00 Civic Si axles.
4.) P28 chipped with DOHC maps and curves, no KS (or P30.)
5.) OBD1 DOHC Vtec Distributor from 93-95 DelSol DOHC Vtec (or GSR?)
6.) 99-00 Civic Si shift linkage
7.) New Hoses for 99-00 Civic Si or 93-97 DelSol DOHC Vtec.
That is all I can think of for now besides a bunch of
Let me know if I am forgetting something, or if something I have listed will not work for me. Thanks.
P.S. I tried the search but had no luck.
!Let me know if I am forgetting something, or if something I have listed will not work for me. Thanks.
you dont need the rear mount for the 99-00 si infact im almost positive its not gonna work in a 92-95 civic. you can use your stock civic rear mount, and the rear bracket you will need to bolt to the rear mount is the one from the delsol or the gsr
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">you dont need the rear mount for the 99-00 si infact im almost positive its not gonna work in a 92-95 civic. you can use your stock civic rear mount, and the rear bracket you will need to bolt to the rear mount is the one from the delsol or the gsr</TD></TR></TABLE>
Correct... direct bolt in swap.... good luck
So, stock rear mount, but delsol or integra rear bracket. That sounds easy enough. Are there any other sensors that I need to worry about that might be different? Oh yea, Injectors, I have a set of 92 prelude injectors, will they work OK? I am pretty sure they will and the 99-00 are a different plug right? Thanks.
Modified by IDriveHonda at 9:30 PM 5/19/2003
KStuned
May 1, 2005 12:29 AM
pennies_hatchie
19
Sep 9, 2003 06:48 AM
