just alittle help here.
just alittle help here with my b16a2 swap.
ALRIGHT. I got a usdm b16a2 engine/tranny and swapping it into the 93 si eg.
Heres a list of what I got so far. tell me if I need anything else or if I got something wrong.
b16a2 Engine/tranny
93 si wire harness
94 integra driver mount. Oh yea it has the 3 bolt pattern to it. Right one?? "do I need the one inside the t-belt too??"
99-00 si rear tbracket
99-00 si shift linkage
94 delsol vtec tbc/bracket
99-00 halfshaft/axles
for the tranny mount can I just use my 93 si mount??
chip p28
anything else I need?? I know I'm going to need the front side mount but is that about it to swap it in??
Modified by Bigballars at 12:27 PM 4/14/2006
Modified by Bigballars at 1:34 PM 4/14/2006
b16a2 Engine/tranny
93 si wire harness
chip p28
Re: just alittle help here with my b16a2 swap. (Bigballars)
94-01 integra or 99-00 Si Coupe front tranny bracket (from any 5speed model)
94-01 integra rear engine bracket (from any 5speed model)
94-01 integra driver side 2-post mount
94-01 integra or 99-00 Si Coupe A/C bracket
94-01 integra or 99-00 Si Coupe complete shift linkage
94-01 integra or 99-00 Si coupe complete axles including half-shaft
For the ECU, you can use a chipped P28, but a P30 from a B16A3 is also appropriate. For the latter, you will need to use up the knock sensor. The stock 93 Si harness will work perfectly. Also, you will need to change distributor and injectors to OBD1.
Re: just alittle help here with my b16a2 swap. (BlueIntegraBoy)
So the things I need to get is the 94-01 teg rear engine bracket "doesn't the 99-00 si rear bracket work??", and is the one with three post on the teg the right one?? cause thats the one I got, unless theres differen't kind.. but other than that I'm all set than. Just making sure.. and about the top tranny mount, I have to get the 99-00 si one right??
benphillips
10-29-2006 07:16 PM
KStuned
05-01-2005 12:29 AM
