b16a2 swap into 1999 ex
i need help to know what i need to do a b16a2 swap with gsr tranny into my civic 1999 ex with a/c and p/s
will the stock motor mounts work or do i need b16 ones
thankx for the help newbe
1 Post
Re: b16a2 swap into 1999 ex (scivicex99)
You'll need the Si (99-00) mount for the rear, and I think the A/C bracket from the Si also. You also need ECU, axles, wiring harness, Helms manual, etc.
You should also search, because there have been countless threads about "I'm swapping ___ into my ___, so what do I need?" Try the FAQ thread near the top of the EG+ forum
Location: Your really lame if you dock my points, WA, 98033
it should be a pretty straight forward swap. just use the 99-00 si rear mount, driverside upper mount and ac mount and you should be gravy. also i think you will be fine on the wireing side aswell. if you get the 99-00 si wiring harness with the swap it shoudl be plug and play. good luck
tampabud
13
02-20-2019 10:11 PM
LsScivic
07-11-2009 12:31 PM
