Fuel pressure problem
Old May 19, 2003 | 05:24 PM
HondaTurbo's Avatar
Default Fuel pressure problem
I have a d16y8 motor with a d16z6 will the intake work properly on my d16y8 head.... my fuel pressure is 58 with the hose on and that is turned all the way down on my regulator is there any way to lower fuel pressure by drilling out something?
Old May 19, 2003 | 05:57 PM
b19coupe's Avatar
Default Re: Fuel pressure problem (HondaTurbo)
You should be able to go a lot lower than 58 PSI with an adjustable FPR. Something is wrong.
Old May 20, 2003 | 06:39 AM
JimBlake's Avatar
Default Re: Fuel pressure problem (b19coupe)
Any way to check if the fuel return line is plugged or pinched? The FPR will go wide open as it tries to drop the pressure, but if the return line is blocked it won't make any difference.
Old May 20, 2003 | 10:33 AM
TGUNNER's Avatar
what fuel pump and fpr do you have??
Old May 20, 2003 | 12:30 PM
HondaTurbo's Avatar
Default Re: Fuel pressure problem (TGUNNER)
i have a bbk fuel pump
jman86
Nov 7, 2024 12:19 PM
alpha_1
Nov 22, 2004 06:13 AM
hybrid_vtec
Aug 5, 2004 10:03 AM
NuclearB18B
Sep 19, 2003 06:20 AM
Malgerus
Aug 16, 2002 01:03 PM
